Old 10-28-2022, 10:07 PM   #1
sc0terdad
Default volvo 740 turbo to volvo 242 gague cluster swap
I'll make this one short,
will a volvo 740 turbo gague cluster fit a 81 242, and if not how extensive would it be to modify one to fit.
thanks
sc0terdad is offline   Reply With Quote
Old 10-28-2022, 10:49 PM   #2
Radtap
Radtap's Avatar
No, 740 cluster is much larger. You'd have to cut gauges off the side and the result would be a taller 240 cluster.
Feedback
Radtap is offline   Reply With Quote
Old 10-29-2022, 12:17 AM   #3
740atl
Gear acquisition syndrome
740atl's Avatar
Have you even looked at the two clusters?
This is Tb… of course it will fit… and the wiring will connect seamlessly.
Old 10-29-2022, 12:22 AM   #4
sc0terdad
ah, thanks
Old 10-29-2022, 12:26 AM   #5
Marvelous3
Who engineered this?
Marvelous3's Avatar
2016 Chevrolet Silverado 1500 Blackout Edition
1991 245+Turbo 16 Valve Microsquirt
Need Lawncare service in Atlanta? PM me for a lawncare and maintenance quote
Old 10-29-2022, 12:27 AM   #6
sc0terdad
no not in person, I gotta be honest I am about a month and a half deep into volvo ownership, I have not been around the block
Old 10-30-2022, 06:18 PM   #7
Old and boxy but good.
Try changing the gauge faces if you want something custom looking.
Happy shopping! https://www.davebarton.com/
Old 10-31-2022, 12:32 AM   #8
sc0terdad
that site is sick!
only problem is I am trying to get a gauge cluster that has a tach (currently an 81) cluster
Old 10-31-2022, 01:48 AM   #9
James M
Bored member
James M's Avatar
You can buy and install a tachometer in your existing cluster. Way less sawzall and twist connectors than running a 740 cluster
I wanna say someone bastardized a 7/9 tach into a 240 cluster here once, don't try to repeat it it's in no way with doing anything but a normal large tach
Old 11-03-2022, 01:21 AM   #10
If it's the backlit look of the 7 series gauges you like. VDO sells Cockpit Vision series gauges that you can fit to the dash. In the upper radio cubby
you can fit three gauges like the turbos and two gauges fit next to the cluster. Volvo made all the dash trim for the gauges and people here sell that stuff and on ebay. Might even be able to get some stuff new from
Volvo. Sitting in the warehouse all dusty.
Old 11-03-2022, 09:35 PM   #11
sc0terdad
thanks, I'll check that out
