Old 10-31-2022, 08:12 PM   #1
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Default Fitting FWD 18x8 ET47 73.1mm bore on my 740
Looking for advice on what spacers I would need to fit the 18x8's (Advanti Hybris) I have off my C30. I have 225/45's on them.
my 740 pickup has stock front suspension, overload rear springs.
I have to place one on it to see if they even make sense style wise
Found this post where they fitted 18x7's, similar offset
My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread
lookforjoe is online now   Reply With Quote
Old 10-31-2022, 09:38 PM   #2
GSWAGON
my other ride is a exmark
32mm to 35mm hub centric spacer/adapter should work perfect. 225 45 18 tire should be ok for stock height
87 765 GS Wagon LT4/T56
90 740 Turbo M46
90 780 Turbo
93 940 Turbo Wagon
99 SL500 AMG Sport
08 Corvette JSB LS3 6 speed
08 Escalade AWD- wifes daily
15 Ram CCSB Hemi 4wd
Life is short, so live it! You are only old when your dreams are replaced by regrets.
GSWAGON is offline   Reply With Quote
Old 11-02-2022, 10:04 PM   #3
lookforjoe
lookforjoe's Avatar
Thank you for the input. I test fit one of them today
Overall diameter
with 1" spacer barely clears, so suggested 34mm should perfect
but.... I'm really not sure I like the open thin spoke on the 740
I have other FWD offset wheels I can try, but in 17".
Old 11-03-2022, 10:31 AM   #4
rb92673
It's a truck. Shouldn't you put on some smaller wheels with bigger tires? Maybe a 3" lift?
Old 11-03-2022, 08:33 PM   #5
lookforjoe
lookforjoe's Avatar
I have the 16's on it now, I'll probably stick with this as long as they clear the 302 brakes. Not going to lift it, I like the handling now, can take exit ramps typically twice the posted speed with no problems.
Old 11-06-2022, 03:43 PM   #6
Old and boxy but good.
I like the bright silver wheel color on a dark blue car. I tried anthracite thin multi spoke wheels and they didn't suit the car well so I sold them.
Old 11-06-2022, 04:28 PM   #7
lookforjoe
lookforjoe's Avatar
I agree. Silver looks best, and thicker spokes. I have some 17" Sparcos in silver, and a couple Volvo variants, but in 15". I'll have to see if any of them look suitable.
Old 11-08-2022, 09:13 AM   #8
lookforjoe
lookforjoe's Avatar
I've found some 32mm 5x108 hubcentric spacers at a reasonable price - they are for a Ford, so I'll get the inner bore turned to 65.1, and use spacer rings to go from 63.4 to 73.1 for the Sparco and/or Advanti wheels. I may swap the 17" wheels off my Mum's 2011 black C70 for my black 18" Advanti's - those look pretty decent & are "chunky" enough, also won't need centering rings since they are already 63.4 bore. She likes the look of the black wheels on my C30
Old 11-10-2022, 07:48 PM   #9
Tonyte619
I can take on ramps at twice the speed in my lifted 745 wagon, my lifted wagon handles better than my lowered 745
The lowered car has bump steer issues, the lifted one corners flatter than it.
Tonyte619 is offline   Reply With Quote
