Old 11-02-2022, 09:46 PM   #1
2 old for this
Default Dies when turning right
B230ft 2.4 in a 240 would shutoff while turning right. It would restart. So I loaded up the parts cannon and replaced all the engine management components. It had good power before and now seems stronger. Fuel economy is up also. One not so good change is on a cold start it has a very much higher idle speed (1800) but comes down after it warms up. It hasn’t died again-yet.
Old 11-03-2022, 11:37 AM   #2
OVERDRIVE
OVERDRIVE's Avatar
Okay
1990 244 DL AW70 189 white.
OVERDRIVE is offline   Reply With Quote
Old 11-03-2022, 11:40 AM   #3
Radtap
Radtap's Avatar
How’s your engine harness, what year? Somethings possibly shorting as the engine/harness moves
Feedback
Radtap is offline   Reply With Quote
Old 11-03-2022, 03:27 PM   #4
Bloody244
happened to me when i lost my battery holding clamp or whatever that is called. the battery shorted on the hood also only on right turns or bumps
'87 244 B230R @14psi 19t, V16t cam, Haltech Elite 1500, Stage 3 overboostracing.se 530 Head, ACM H-beam rods, Do88 intercooler, Accumulator Mod AW71
Instagram https://www.instagram.com/blue__244/
Rip '87 B230f+t it did not stay window free 25.06.2021
Bloody244 is offline   Reply With Quote
Old 11-05-2022, 09:45 AM   #5
Theres a lot of reasons this could happen, I think once upon a time I had a similar situation and it was the insulation on the fuel pump wiring that had degraded.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-05-2022, 08:45 PM   #6
2 old for this
First thought was the tank pump hose has failed. Inspection showed no problem. Main pump harness is ok. Problem has not returned.
