Old 11-06-2022, 02:07 PM   #1
Polar971
Default 960 or S80 gasket?
Hi all, I have a B6294T block from a S80 (2004) and I am putting the cylinder head from an old 960 (1992) . The car is going to have a turbo. My question is, which cylinder head gasket should I put on it, the one from a 960 or the one from the S80?
Because if the car is going to be turbo, shouldn't it have a gasket that supports that pressure?
Thank you very much
Polar971 is offline   Reply With Quote
Old 11-08-2022, 05:56 PM   #2
classicswede
Volvo upgrades
Same gasket
http://www.classicswede.org/
Old 11-16-2022, 08:23 PM   #3
mck1117
Originally Posted by classicswede View Post
Same gasket
they're not quite the same - they do have the same basic shape, but have slightly different cooling restriction ports
I'd run the S80 gasket since you're using the S80 cooling system.
mck1117 is offline   Reply With Quote
