Old 11-20-2022, 08:59 AM   #1
DailyDriverMods
DailyDriverMods's Avatar
Default Milling piston crown of late model NA piston
Hello everyone,
I am currently stepping up the game a bit with my turbobrick. I have a '91 B230F+T setup that is currently getting some head work and rods. The setup will be:
- B230F '91
- Maxpeeding rods
- 530 head with 46/38 stainless valves
- IPD Cam with KLRacing 39KG valve springs
- KLRacing intercooler (late style 940 type)
- Megasquirt 3 ECU
- Siemens Deka 630CC injectors
- 16T turbo with 3" downpipe / 2.5" exhaust system
- 90+ exhaust manifold, stock B230F intake manifold
The engine has to run on 93AKI/98RON fuel and i would like to up the boost a bit. Currently it runs fine at 15psi without any signs of detonation but i would like to up the game a bit later on by upgrading to a G25-550 turbo and increasing the boost to about 20~22psi.
I calculated that the current compression ratio is about 9.6:1 when assuming the 530 head volume is 51.7cc. This seems to be a bit on the high side for my power targets at pump gas.
Deshrouding the valves and doing a small bit of work on the combustion chambers would hopefully net me about 3cc of additional volume but that isn't really enough to drop the compression ratio to the levels i need.
So i measured the NA piston crown thickness which is ~7.4mm. I would like to mill a small bit of the piston crown to make the dish 0.4mm deeper and increase the dish radius from 68mm to 75mm since the squish band on the 8V combustion chamber isn't really that wide. Milling the piston dish would net me another ~3cc of additional volume which combined with the head work would net me a compression ratio of about 8.8~8.9:1.
Is there any experience with milling down the NA pistons or is this really a no-go area? I would like to hear your opinions/experience.
[1991 Volvo 240 sedan, daily driver ] [B230F|IPD Turbo Cam -2*|MS3x|145HP/215NM|M47]
~Gotta love that GL trim~
The excessive TD04 turbo guide ®™
MS3 thread including MS3 tune
DailyDriverMods is offline   Reply With Quote
Old 11-20-2022, 10:25 AM   #2
shoestring
shoestring's Avatar
I don't have experience with milling pistons as you asked, but I do have experience with the chamber volumes. The stock, untouched chambers in 530 heads I have measured with stock valves in them come out to 54.5cc, +/- a little bit, <1cc. The difference in the shape of the valve head faces you have chosen will reduce the chamber volume marginally.
My advice would be this: considering you're looking at doing something somewhat unusual, it's best to make sure of all of your measurements and leave nothing to chance. I would fully prepare the head and then calculate compression ratio. From there you can plan a best course of action.
You may be looking at a small enough number that an operation like this is unnecessary. For example, a 0.030" head gasket is about 5.5cc, where a 0.040" head gasket is about 7.3cc. Either one puts the squish in the accepted range for detonation resistance, while providing a fair amount of compression ratio change.
I would also advise to seek other opinions. I like the combination you've chosen and hope you keep us updated on it.
Old 11-20-2022, 12:13 PM   #3
culberro
culberro's Avatar
I’d unshroud the chambers vs machining the pistons. You can easily get to 8:1 with F pistons and modified chambers.
It is common practice to machine turbo pistons 3mm shorter when using a 86mm crank. The turbo pistons have more material and a lower ring placement.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 11-20-2022, 06:54 PM   #4
740atl
Gear acquisition syndrome
740atl's Avatar
How much will it cost to remove the pistons, have them milled, then reinstalled, vs just purchasing quality low compression forged pistons?
Iirc, the 8v head’s don’t respond well to messing with the quench distance unlike the 16v head.
Old 11-20-2022, 07:09 PM   #5
mikep
The MP
mikep's Avatar
Leave the piston height.
I removed .100" from dished pistons once but decked the block .120" to get more quench and higher compression.
Deshroud the valves a lot using a ball shaped burr or a fat round-end burr. Be careful, do lots of layout marking, and remove one curve x 4 chambers at a time. Deshroud both sides of the exhaust, but only the exhaust side of the intake. Deshrouding the short turn side doesn't help as much going in.
Also pay a lot of attention to the exhaust short turn, and the rest of the exhaust port and bowl.
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
Originally Posted by leecatd8209 View Post
I just looked up the Del Taco menu and am about to buy a plane ticket
Old 11-21-2022, 09:39 AM   #6
DailyDriverMods
So it seems like it would be best to first do the head work and then see if i need those extra couple of cc's in the piston dish. For the head gasket i'm using an original style Elring gasket with stronger 10.9 grade head bolts. That gasket should be 0.047" thick according to tbricks knowledge. We have an in-house dyno so i'll keep you guys posted with results along the way.
Do you happen to know the exact piston crown thickness of the turbo pistons?
The pistons are already cleaned up and laying on my work bench. Fortunately i can mill them myself so that would give me a net cost of 0$ which is kinda tempting. A set of forged Wiseco's with a 14cc dish costs ~€800 around here in the Netherlands and they don't install themselves unfortunately.
When machining the piston crown my intention is to keep the squish as-is since you guys found out the 8v head benefits from it. Only the dish will be made deeper and wider. The actually functional squish area will stay untouched. And thx for the tips for porting the head. I have access to a Serdi to cut the valve seats and do the initial radius for deshrouding the valves as much as possible to the sides of the piston wall. All the other stuff is still hand work unfortunately. I really don't know much about porting in general but a quick read through "David Vizard's How to Port & Flow Test Cylinder Heads" book gave me a bit of insight in the basics of head flow and completely corresponds with your advice.
Old 11-22-2022, 04:10 PM   #7
DailyDriverMods
I did some work in solidworks and 3d printed a mould to mark the combustion chamber outline for porting. I took some inspiration from the book about porting 8v cylinder heads and the 531 head that was ported with help from Porsche. My idea is to keep the floor of the combustion chamber untouched but radius it further out to the outline. What do you guys think about it? Did i go too far on the exhaust side?
(pictures are clickable)
Old 11-22-2022, 04:33 PM   #8
culberro
culberro's Avatar
That's too much material removed from the exhaust side in my opinion.
If you remove that much material from the spark plug side of the exhaust valve, you will hurt flow. This is from more exhaust gas flowing through the spark plug side of the valve pinching (reducing) the faster flow coming from the opposite side of the chamber.
You want 6-8mm removed from the edge of the valve for full unshrouding. Anything more is going to hurt higher lift flow.
Old 11-22-2022, 05:11 PM   #9
I.M. Weasel
My machinist said not to touch the exhaust side at all but he did take some out around the intake valve.
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 11-23-2022, 05:25 PM   #10
DailyDriverMods
So after a couple of hours printing and adjusting the 3D drawing i came to a new result. I altered the shape a bit, especially on the exhaust side. And it can easily be mounted now using the valves. I'm feeling pretty good about this one, what do you guys think? Once it's good i'll share the 3D printing file here.
Pictures are clickable again.
Old 11-23-2022, 06:01 PM   #11
mikep
The MP
mikep's Avatar
This weekend I can take pics of what i recommend. I use a marker and draw a continuous radius from the widest part of the ex valve.
Old 11-23-2022, 07:14 PM   #12
culberro
culberro's Avatar
Here’s a pic of what I’d consider the maximum amount of chamber unshrouding you’d want to do. It was done because another shop butchered the head when they installed 46/40mm valves in a completely stock head. Good news, owner is using a somewhat mild cam and a turbo, so you can focus on lower lift flow.
https://flic.kr/p/2mEboYa
MikeP, I’m curious to see your approach as well!
Old 11-24-2022, 04:44 PM   #13
mikep
The MP
mikep's Avatar
pics from 19 years ago showing a super-conservative approach aimed at making a head that works ok with an NA B21:
Note, I left the far side of the intake alone this (my first with a 530) time. It seemed open enough, but I use a ball to curve it now. This is still slab-sided all around with sharp corners. I had ported a few heads, mostly chev and pontiac and a few fords. But I had no idea on this head.
There was no way to get pics of the runner work, and I don't have pics of the bowls or the back-cut valves. The faces have been shined up a wee bit and you can see the rounded exhaust corners in the chamber. It also looks like I backed off on opening up the near-side intake area of the chamber.
Old 11-24-2022, 04:55 PM   #14
culberro
culberro's Avatar
Mike, looks great!
Old 11-25-2022, 10:49 AM   #15
shoestring
shoestring's Avatar
I use the David Vizard bathtub chamber formula to determine deshroud amount. It's: radius from valve stem centerline=(chamber depth*coefficient of discharge)+(0.5*valve head diameter). Basically it works out to clearancing 5-6mm around the exhaust valve, depending on how much you've taken off the head. Very little comes away from around the intake valve using this method. Looks extremely similar to Mikep's pics above.
Old 11-25-2022, 02:49 PM   #16
mikep
The MP
mikep's Avatar
I'm actually looking forward to doing the chamber work, not sure how the pics will be. I also have been meaning to do some posrt pics, but I think someone already did a good job of those.
It looks like I might not be able to do the chamber work this weekend, though. I am doing some wiring. I want to use deutsch connectors to mate microsquirt to factory harness so the engine comes out easier. So I'm in the middle of that. Maybe I'll get on it Monday.
But if you lay it out and remember you are guiding and curving the air like a wing, and make it a bowl (hemispherical) so the exhaust (gas) doesn't have to turn as sharply to get under the partially open valve, that's a start.
The valve is only open at max lift for a brief time. It spends a long time opening and closing, comparatively speaking.
Old 11-25-2022, 05:45 PM   #17
classicswede
Volvo upgrades
A good point David Vizard does make is that low lift and half open flow of the valve is much more important than full lift flow
http://www.classicswede.org/
Old 11-27-2022, 10:36 AM   #18
DailyDriverMods
I've made some small changes to the shape again and now i am practising on a spare 530 head. I first marked the combustion chamber and then i went ahead with the carbide cutter. Some ink from the marker went under the 3D printed gasket but the outline is still very obvious. It isn't polished or anything like that but i do like the shape. I am aiming more towards achieving good low-lift flow since the mild B230 cams don't really have that much high-lift duration.
Any tips for smoothing out the ported surface?
Old 11-27-2022, 09:24 PM   #19
mikep
The MP
mikep's Avatar
I use a burr (coarse for aluminum), then stones, then hard-rolls, then flap sanders (which are available in 40, 80 and 120 grit..avoid 40..).
Stones tend to clog on aluminum, so do fine burrs. You can try oil or wax on stones, but some also resist clogging better. Very coarse stones are worse. High speed (heat) makes it worse.
You will find that the large flap wheels are better in large curved areas, and some get worn to a good shape for others.
https://www.aaabrasives.com/standard...120-grit-stock
https://www.amazon.com/Abrasive-Sand.../dp/B08R2YX8WB
Old 11-27-2022, 09:26 PM   #20
mikep
The MP
mikep's Avatar
Clean and shape your stones with an old stone or with a dressing stick
https://www.amazon.com/Norton-Abrasi...df_B007O6VF52/
Old 11-28-2022, 07:30 PM   #21
DailyDriverMods
Thx for the tips, the next step will be trying to clean the chamber up so i'll get back on this later.
I have completed the shaping of the combustion chamber, it's still very crude but the shape looks allright. I have also CC'd it and it measured as a 57cc volume. That brings the compression ratio down to about 9:1 which isn't enough for me. I'll probably mill the dish in the piston 0.5mm deeper which should get me to about 8.7:1 and keeps the quench surface.
Here are some pictures again:
Old 11-28-2022, 08:34 PM   #22
mikep
The MP
mikep's Avatar
That should do it.
If you are able to trace that shape on a piston you could remove the raised part where material is missing on the head.
Old 11-28-2022, 08:57 PM   #23
bobxyz
bobxyz's Avatar
Out of curiosity, what's the tradeoff between:
1) lower static compression ratio with higher boost pressure, and
2) higher scr with lower boost pressure ?
Both can give the same pre-ignition peak cylinder pressure, but #1 must be preferred for some reason since factory Turbo engines usually run lower SCR than the NA version of the same engine. Is it a charge temperature issue -- boosted intercooled air is cooler than the equivalent extra compression?
bobxyz is online now   Reply With Quote
Old Yesterday, 08:09 AM   #24
mikep
The MP
mikep's Avatar
Low static (mathematical) compression with higher boost give more linear pressure drop from TDC to BDC. (higher BMEP for a given peak pressure, compared to high static compression)
High static compression gives better off-boost torque, less BMEP/torque with the same peak pressure near TDC.
Old Yesterday, 02:22 PM   #25
DailyDriverMods
I was puzzling a bit with the setup again of the engine. Since i'm probably going to be running the 16T for ~6 months before i'll swap to the G25-550 the head flow will be a bit overkill i think. So i was toying with the idea of putting in a T cam for the time i'm running with the 16T, the ported head with bigger valves should make the T cam a bit more revvy right?
