Old 11-23-2022, 05:22 PM   #1
thevolvokid
142 whore
thevolvokid's Avatar
Default 72 Volvo 142 - Carb Questions
Hello All,
I recently brought home my 142e, 19 years ago I converted it to a Weber 32/34 since the Djet was ruined in the car. Motor has been bored, Isky cam, head work etc - all done back in the 90s before I bought the car.
All that being said, I have a terrible 32/32 downdraft Weber on the car now. I'm wanting to upgrade the carb to maybe this https://www.amazon.com/Team-Performa...7FYRQ8VL&psc=1. Has anyone recently picked one of these up? Thoughts on them. I'd like to do some 40 DOCEs but the budget isn't there currently for them. Any other suggestions from anyone? It's been a while since I've worked on the car, 14 ish years, so I'm trying to remember all the things I knew back then
90 745 Turbo, tuned by myself made 365 whp completing a 1/4 mile pass at 12.93 @ 105.xx. Not bad for a stock block w/ 265,xxx miles that runs lh 2.4 and ekz
thevolvokid is online now   Reply With Quote
Old 11-23-2022, 05:26 PM   #2
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Paging Broke4speed...
The Asian Weber copies are really hit or miss. They're cheap for a reason.
A genuine 38/38 DGES would serve you a lot better, but of course it's like 3-5x the price, depending where you go.
Doing the wrong thing the right way.
Get f*cked and please have a nice day.
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
Originally Posted by Cwazywazy View Post
my balls have more wrinkles than my brain
Originally Posted by leecatd8209 View Post
Against all odds I have overcome the 4
-1967 144S
-1983 245 Diesel (Current Project) - passively for sale (interested in trades!)
fatcatbestcat is offline   Reply With Quote
Old 11-23-2022, 05:31 PM   #3
Broke4speed
Broke4speed's Avatar
Yeah, the chinese carbs are reaaaaaally hit and miss. I've had some good ones, and some bad ones...but sometimes the bad ones can be fixed if you know what you're doing. Sometimes it's just an awful casting and you need to throw it away. The 45 Chinese Amazon DCOEs I have are like that, they leak through the porus casting.
TBH, get a real weber, you'll thank yourself .
1984 244/ LR4 4.8 / T5
Old 11-23-2022, 05:36 PM   #4
thevolvokid
142 whore
Yeah I'd love to put some true Weber DCOEs on the car but man SPENDY lol.
I hear lots of things about the Chinese carbs being hit or miss; the 32/32 on it now is pissing fuel out of the accelerator pump. It's already under sized and my 32/34 I had on it forever ago never was quite right. So I figured 3rd time is the charm?
Old 11-23-2022, 10:13 PM   #5
spock345
spock345's Avatar
I'd go find a used Weber 38/38 DGES. I assume you are used to tuning the DGV on your car right now.
You could also try a holly. I am not sure if the bolt patters are the same but there are probably adapters.
Whatever you choose you are going to need to be ready to spend some time jetting it right.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
spock345 is online now   Reply With Quote
Old 11-23-2022, 10:29 PM   #6
fatcatbestcat
Professional Hack
Holley 2bbl would be convenient if you ever wanted to put EFI back on it - I believe you can get 2bbl-format throttle bodies to work with the Terminator or Predator-whatever they're calling the DIY EFI systems these days.
Old 11-23-2022, 10:30 PM   #7
spock345
spock345's Avatar
I was really tempted to go that route until I got my SUs figured out. An out of the box EFI solution probably won't give more power, but size the barrels right and you'll probably be a lot less restricted than the current progressive weber.
IIRC Volvo used a 40mm 2bbl Solex in their GT kit along with a higher compression head, dual port exhaust manifold, and a D or K cam.
Old 11-23-2022, 10:39 PM   #8
59volvo
why not use dual SUs?
59volvo is offline   Reply With Quote
Old 11-24-2022, 12:55 AM   #9
spock345
spock345's Avatar
HS6s would probably do the trick. Depending on the cam and compression OP is running. SUs are not all that happy with low idle vacuum.
Old 11-24-2022, 12:09 PM   #10
thevolvokid
142 whore
I need to go back through my records to see what the cam specs are. I just remember its an Isky cam.
Old 11-24-2022, 12:10 PM   #11
thevolvokid
142 whore
I found a 38/38 about 2.5 hours away for sale. Dude refuses to ship it & I don't have a full day to dedicate getting it lol
Old 11-24-2022, 04:07 PM   #12
spock345
spock345's Avatar
How much are they asking?
Old 11-24-2022, 04:30 PM   #13
mikep
The MP
mikep's Avatar
only 2.5 hours? I'd be in the car already.
I personally would put a rochester 2jet on it. I'll mail you some for free.
Also, I have a pair of scabby solex side drafts that came off a B18 marine race engine, I would part with those too if you fine manifolds. I gave away my one good manifold (one was broken).
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
I just looked up the Del Taco menu and am about to buy a plane ticket
Old Today, 12:06 PM   #14
thevolvokid
142 whore
Ad said 75, then he said 100 obo. It was flakey and not strong feelings of this deal is going to work out well.
Old Today, 12:07 PM   #15
thevolvokid
142 whore
What did the Rochester come off of? Do those fit the weber intake?
Old Today, 12:10 PM   #16
thevolvokid
142 whore
Small update, I found the parts needed for the 32/34 to make it whole. I put it together and got it on the car yesterday, didn't want to run really but it could and didnt leak fuel all over so its a back up now. I purchased one of the cheapys off amazon to see how it is. If it is bad I'll just return it and search for a better replacement.
