Old 06-28-2021, 12:36 PM   #26
89_740Turbo
89_740Turbo's Avatar
I was driving in my old 740 during a rainstorm and had to drive through a big puddle because I couldnt switch lanes. I was running IPD lowering springs so, closer to the water haha. When I woke up the next day and turned it on, it was puttering and sputtering. Sounded like stomach ache farts. Anyway, I checked the spark plugs and spark plug wires - discovered that water has affected 1 of my spark plugs and moisture was inside 2 spark plug wires. I changed the spark plug, checked every other one too, dried out the spark plug wires and opened the distributor and sprayed a little wd40 on it to remove any moisture. After that, the sputtering and puttering stopped and it ran smoothly again.
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 06-30-2021, 02:47 PM   #27
DavePolyakov
Pulled my spark plugs they each had a gap around 0.028-0.030. I noticed the threads were oily. I've been told by my friends that when I'm boosting in front of them on the road they see black smoke pop from the exhaust. Is this lh2.4 dumping fuel when it sees more than 7psi? Some TLAO chips may help?
Old 06-30-2021, 03:02 PM   #28
Might be that the PCV system is not working well. That puts some oil into the combustion chamber.
Old 06-30-2021, 03:07 PM   #29
DavePolyakov
I just cleaned all PCV components. The plugs look ok though right? The issue probably lies elsewhere?
Old 06-30-2021, 07:18 PM   #30
Yes, I agree that the plugs look ok. Maybe try a slightly thicker oil like 15-40w and see if that improves. You can also with a cold engine remove the intake hose and check the turbo for excessive shaft play.
