Project Get Out of Its Own Way V.2
Cut the dash to fit in the new shifter and cut the coil bracket to let the coil clear the brake booster.
<a href="https://ibb.co/n05fynf"><img src="https://i.ibb.co/PYf4y94/1-C4-A5-F85-9376-487-E-8-C2-F-9-D55293-C9-F1-C.jpg" alt="1-C4-A5-F85-9376-487-E-8-C2-F-9-D55293-C9-F1-C" border="0"></a>
<a href="https://ibb.co/YBRpZqC"><img src="https://i.ibb.co/60ngBfM/7476-F0-AD-1709-460-F-8-B3-F-AD4263-E20071.jpg" alt="7476-F0-AD-1709-460-F-8-B3-F-AD4263-E20071" border="0"></a>
<a href="https://ibb.co/hsjhHxX"><img src="https://i.ibb.co/4WG9Mws/71-D71060-A1-CE-467-C-9-DE9-D4332-D28117-D.jpg" alt="71-D71060-A1-CE-467-C-9-DE9-D4332-D28117-D" border="0"></a>
<a href="https://ibb.co/sKKP6gY"><img src="https://i.ibb.co/D99b812/2-D9-EE3-D3-9-FC9-492-E-8732-D835-A05-D7-F78.jpg" alt="2-D9-EE3-D3-9-FC9-492-E-8732-D835-A05-D7-F78" border="0"></a><br /><a target='_blank' href=
Mounted few things today, the coolant hoses, new over flow tank is now mounted. Going to start working on the exhaust and intercooler piping next. After that I can start wiring it up.
2.5 bar map sensor Barb was larger in diameter than stock one. Drilled out a larger hole to get it to fit.
Didnt realize I had to drill through 3/8” of metal to just get the screw hole through.
The turbo took the spot of the factory overflow tank.
Got most the exhaust done and installed. The GM throttle cable is now adjusted right and the cooler is hooked up and mounted. Waiting on vacuum block and I’ll do the vac lines next. After I’ll start wiring up the terminator X.
About ready to wire it up.
<a href="https://ibb.co/cY1RXYq"><img src="https://i.ibb.co/qJdhFJ6/DEF999-D7-1-DDE-4-B18-81-EE-DC3-F46-D3-B836.jpg" alt="DEF999-D7-1-DDE-4-B18-81-EE-DC3-F46-D3-B836" border="0"></a>
<a href="https://ibb.co/fDDw1CB"><img src="https://i.ibb.co/1zzWv9h/963-A0084-8-AA0-44-EC-BF27-B5-CD4-B6-F4654.jpg" alt="963-A0084-8-AA0-44-EC-BF27-B5-CD4-B6-F4654" border="0"></a>
<a href="https://ibb.co/m6WPBH6"><img src="https://i.ibb.co/86ZQBj6/3-E5115-F0-5-E1-B-48-E5-9-BD0-C9009-D16-A3-D1.jpg" alt="3-E5115-F0-5-E1-B-48-E5-9-BD0-C9009-D16-A3-D1" border="0"></a>
Starting to wire it up.
<a href="https://ibb.co/wwTFSfw"><img src="https://i.ibb.co/vQb63SQ/E27244-E0-EC26-4155-9564-4230-BE4-DDBA4.jpg" alt="E27244-E0-EC26-4155-9564-4230-BE4-DDBA4" border="0"></a>
<a href="https://ibb.co/ccjVKYq"><img src="https://i.ibb.co/mC3grNp/4-DED2-BA1-4816-4286-BCAD-3176-C86-AD578.jpg" alt="4-DED2-BA1-4816-4286-BCAD-3176-C86-AD578" border="0"></a>
