Hello, been lurking these forums for a while and I have come to pick your brains. Have a 86 244 project that I am putting the shine on and in the early planning/budget stages for a b230f+t conversion with standalone ems. Hoping to use a fairly solid td04-12b and new set of the latest gen bosch 19lb injectors I have in a box. Likely will use SDS management system if I pull the trigger but hoping to save a few hundred bucks if I can. Has anyone tried the NA injectors under a low boost 6-8 psi situation or would I be asking for trouble?
