Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Is it the same front spindle for an ABS or non-ABS equipped 740? For some reason my car has the ABS tone ring on the wheel bearing event though it's not an ABS equipped car.
The only difference is the sensor on the spindles. all the other geometry is the same. Pretty much any replacement hub will probably come with an ABS ring.
Been trying to find clean spindles to replace mine that are rusted to oblivion. Weird because there is absolutely not rust anywhere else on the car. My guess is that the previous owner replaced the spindle/shock assembly at one time with used parts.
I may try to have them blasted and will see how they come out.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
