Old 03-29-2003, 05:04 AM   #101
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Well... time to unveil my secert. It's a bit early as I have the dyno tomorrow but didn't have time to wire up the AIC yet. So its going to have to be on low boost.
Ok, now that disclaimer is DONE time for the good news:
HOLSETS WORK ON A STOCK MANIFOLD AND A B21FT!!! :D
Now, this is a quickie write up as well. I'll be writing an article on the swap asap here but heres my thoughts:
Over all, quite a responsive turbo. I've been having problems sorting out some bugs so I kept my MBC down (and haven't been able to romp it much yet) but Im seeing peak boost (only 14 at the moment) in first gear by about 3500 rpm ish. Now, its really hard to say because when it hits, it HITS. After sending the elbow off the turbo into the hood I've been kind of reluctant to try to hammer it, but I solved the problem and decided to try again. All I have to say is it hauls ass.
Now, as for the install, its involved but not to bad. I'll post some pics, but you'll have to bear with me as all the silicone adapters I ordered (last week) still aren't here so I had to get "creative".
So, what have we learned? b21ft's will spool a holset WH1C!
Now, for the bad news. I really think that the head work, cam (now you can see what I choose what I choose) and intercooler is a must. Obviously extra fuel is too, though its still doing ok at 14psi. With out being willing to put in some over all effort a Holset is a waste of time.
Also, next time around Im getting an HX35 that already has the wastegate actuator point out the front, not the side. I had to make a "bracket" (I will use that term loosely).
Ok guys, debate that one all you want. Tomorrow I'll get some real info up (now that things aren't flying off the motor)
(dont worry the blue hose goes away soon)
Old 03-29-2003, 05:07 AM   #102
Hank Scorpio
I also installed an NPR intercooler, the K15 cam too. I didn't get to wire up the AIC yet so thats still on the list.
Heres the IC
The stock location for the oil cooler doesn't fit with the new IC so I mounted it horizontal on the strut tower. Came out good I think:
And the latest pics!
Doug
Old 03-29-2003, 05:08 AM   #103
Hank Scorpio
Oh, some good sound/video clips:
http://kauerkreations.com/MVI_0499.avi
http://kauerkreations.com/MVI_0496.avi
Doug
Old 03-30-2003, 01:05 PM   #104
Hank Scorpio
Went to the dyno yesterday, couldn't even keep the hoses on so I crossed my fingers and hope'd it would hold.
Well it did and exposed a new problem. That turbo is sucking so hard its completely colapsing my k-jet snorkel, even with the supports.
So the verdict is in, I'm ordering up a MegaSquirt EMS system tomorrow with 58lb injectors. This should really simpilfy things and I get a new toy to play with.
So I bet your wondering, how bad did it to. Try 140 hp. As soon it started to make power and boost it would just try to kill itself. I was also having problems with the wastegate trying to open early, so I'm getting an EBC (haven't decided what brand yet) to help. If after that I'm still not happy I'll start spraying with a 50shot of the line to help spool up :D
The dyno sheet is pretty funny to look at. It's really lackluster below 4k (once again, alot of that is due to the wastegate again) but it doubles its hp in 500 rpm before it just fell on its face. I've got issues, but I'm getting a handle on them.
So its getting there... its really got most of the pieces in place for some serious HP just have to uncork it.
Doug
(ok don't laugh)
Old 03-31-2003, 04:25 AM   #105
Hank Scorpio
Here guys, took some pictures... heres my favs:
Old 04-04-2003, 08:25 PM   #106
Hank Scorpio
Updates!
Got the wing back on it, looks pretty sharp still!
Also, parts are starting to show up again. I ordered a Megasquirt EMS (engine management system), MSD6al, Blitz SBC-S electronic boost controller and a bunch of other odds and ends.
So heres a few pics (the EBC is at the bottom)
Doug
Old 04-08-2003, 01:36 AM   #107
Hank Scorpio
Well, got started on my Megasquirt DIY EMS system.
Thought I'd share ;)
Old 04-12-2003, 08:41 PM   #108
Hank Scorpio
Well, finished building up my Megasquirt EMS. I love it, it was not only a kick in the butt to build, it was pretty straight forward.
I'm also learning to use the software, its pretty slick too.
Anyways, heres some pictures:
Using the software
hahaah I had to customize the case a bit ;) Course I did use green LED's instead of the ones that came with it.
Doug
Old 04-19-2003, 10:03 PM   #109
Hank Scorpio
Well, after a week where I just couldn't touch the car, started back on it today. Got everything on the engine wired, except the distributor. Got the MSD boxes mounted, but just wore out before I could wire it up.
So, really just have to get the fuel pump relays up and running, MSD box running and get my fuel injectors figured out. Had some lucas 53 lb/hr injectors but I just cant come up with a way to make them fit. So, it may go the week on stock Turbo injectors... but eventually something bigger.
Have the Davis (BIG) volvo car show next weekend, should be intresting.
So enjoy!
Adapter a 850 TPS switch needed for use with EMS
Test fitting of HKS turbo timer and Blitz SBC-S boost controller
Mounting of hte MSD boxes
Old 04-19-2003, 10:07 PM   #110
Hank Scorpio
Oh, I just wanted to add a little update on the big picture on the car. So far, since august, Im 10k into the car :eek: but its getting there!
Also, really wanted to thank ipd (ofcourse) and ATP Turbo (www.atpturbo) for being outrageously helpful, and being great about my 20 changed orders!
Also, Dave Lot, John Parker (v-performance.com) and countless others. Less than a year, and the cars almost done!
Doug
Old 04-23-2003, 10:08 AM   #111
Hank Scorpio
Engine harness is done and all hooked up. Actually, everything is, except the injectors leak like crazy (trying to adapt some Lucas 53lb/hr injectors) so I'm headed out to a junkyard today to find some low impedence temporary injectors.
Heres some pictures: (Oh, still waiting on the elbows to come for the turbo to IC piping, I ordered to big DOH)
Just for visual's sake on that pipe
Doug
Old 04-24-2003, 12:43 AM   #112
Dan
TQ>HP
Dan's Avatar
Default Be bop
Car is fantastic Doug, Is that air filter permanent? Dan242tic
Old 04-24-2003, 01:25 AM   #113
Hank Scorpio
Thanks man!! The filter is permant, the location isn't yet. Though, my air intake temps didn't show any difference after almost of an hour of the car running tonight.
Which brings me to my point, ITS ALIVE!!! From k-jet to EMS in two weeks :D
Heres a completed pic, sorry its blury. Tomorrow the rest of the dash goes back together then the fun begins!
Old 04-26-2003, 12:19 AM   #114
Hank Scorpio
Alrightie!! It's detailed and finally at a point where I think I can say "its done for a week!"
Heres some pics!
Sorry they are dark, just finished tonight getting it ready for the show this weekend.
Old 05-01-2003, 02:43 AM   #115
Hank Scorpio
Weekend Update ;)
Alrightie!!! Well, made it through the much awaited for Davis Golden Gate/Sacramento VCOA chapter Volvo Show and the car made it there under its OWN power :D :D!
Babied the car to get it there... but today I decided to see how she goes, and I must say, QUITE well!! Current injectors are maxed at 100% duty cycle by 10 psi though :eek: thats always fun. So I'll be getting bigger injectors soon, but over all, the car runs great!
I think Im going to try advancing the cam 2*, just bring that power down a bit, comes on about 3k right now, but really comes alive at 4k. If I can get it to about 3500-3700 that should just be ideal. Course, Im not really winding the car out to the desired 7500 yet either ;)
Picking up new wheels for the car this weekend, 17X7 Moda R6's and I am PUMPED! So look forward to pictures of those hopefully on the car saturday.
Next project, has to be the T5 swap. My rear main is leaking again (long story) and I refuse to pull it just to put an m46 back in. Then, injectors, then roll cage, Crossdrilled rotors and then maybe, just maybe I'll be almost done ;) From August last year till now, (about 8-9 months) I've come this far, I just may finish this car in a year!
... course, that depends on what you consider finished. I still may (probably will) through a 50shot of NOS at the car too.. for spool up ;)
Thanks guys,
Doug
Old 05-01-2003, 02:44 AM   #116
Hank Scorpio
Oh btw, heres a nice pic (just like to take pics!)
Old 05-03-2003, 10:12 PM   #117
Hank Scorpio
Got a new set of "toys" ;). Moda R6 in 17X7 with 225/45/17 P7000's on them... not my ideal choice of tire but I'll take em :D
Anyways, need to space them out just a hair more, one of them is rubbing but over all I looooooove them!
Old 05-15-2003, 08:31 PM   #118
Hank Scorpio
T5 adapters via John Parker came in today!! I've got the motor out of the 242 again to help test fit the tranny, and to do a bunch of other stuff I have planned. :D The next two months are going to be another whirlwind guys, keep an eye on this thread!
Doug
Old 05-17-2003, 07:53 PM   #119
Hank Scorpio
So in a wierd form of Deja Vu here ya guys go!
So begins the start of the end ;) Last phases of the project is stripping all the parts and painting the entire chasis and engine bay the same color as the body of the car. Also going to pull the dash out and make a custom facia and use nothing but Autometer Carbon Fiber faced gauges!
Should be pretty slick, so stay tunned! Also have some last new surprizes on the motor as well!
Doug
Old 05-30-2003, 07:49 PM   #120
Hank Scorpio
So Idecided enough manual labor for a day, time to do something fun. So first try on our CNC at work, got this damn near perfect!
So, should I (when I do the final one) paint it to match the car, mill it out of Aluminum or Carbon Fiber (provided I can get a sheet of it).
Also, cleaned the chasis, but after a few days I realized with out sandblasting I was never going to get it clean enough to do what I wanted. So, alas the next one will have the perfectly detailed chasis.
Thanks guys enjoy!
Old 05-31-2003, 06:37 PM   #121
Hank Scorpio
Today got under the hood preped and primed, just have to go get the paint in the next day or two and start spraying!
Also got the motor stripped down to a long block again. I think I'll leave the cylinder head off untill I get closer to putting it back in (help keep dust out of the motor), basicly just cleaning it (looked pretty nasty again), fix a bunch of oil leaks and do a few other things.
Heres a couple pics
Old 06-01-2003, 12:07 PM   #122
Pbase must be down for now. I saw the pics earlier. Looks really
good, bud. Just love Project 242ti!! :thumbsup:
Old 06-01-2003, 04:24 PM   #123
Hank Scorpio
Thanks bud! :D Pbase has been hit and miss the last couple weeks, so if no pictures show up, check it in an hour ;)
Doug
Old 06-03-2003, 08:56 PM   #124
Hank Scorpio
:D Not bad I think. Got the first coats on tonight, do some color sanding tomorrow-thursday and hopefully get some clear coat on it by this weekend!
Woo Im proud of myself lol
Keeping the blue motor, just wanted to see if I still liked it (still do). I also need to use one of our smaller guns for up under the strut towers and such... maybe actually mask off the a-arms this time DOH
lol, still not bad I think
Doug
Old 06-06-2003, 09:16 PM   #125
Hank Scorpio
All done:
