Old 05-08-2018, 01:38 PM   #1
mrnabisco
mrnabisco's Avatar
Default Cam For NA 945 - A or B?
Wanting to swap a cam into my NA 94 945 auto.
I put an IPD VX in another automatic 945 I have and it seems OK. Can feel a difference, but not the same as running a manual tranny (where you can control the rpm more).
Thinking of an "A" cam or "B" cam for the other 945.
Anybody run either the "A" or "B" in a 940 automatic? Impressions?
Thanks for any input.
mrnabisco is offline   Reply With Quote
Old 05-08-2018, 02:33 PM   #2
nitroboie
Get the A since you'll need it to have a slot, unless you're running the block mount distributer or coil packs. They're really so close that I doubt you'll know the difference other than on a dyno.
'90 244
'94 945T ipd cam, springs, sways, brace, 16T, TLAO chips, wasted spark, do88 IC
nitroboie is offline   Reply With Quote
Old 05-08-2018, 05:45 PM   #3
mrnabisco
mrnabisco's Avatar
Thanks.
The 945 has Regina with side distributor, which is why I was considering a "B" cam.
Old 05-09-2018, 05:34 AM   #4
reed
reed's Avatar
I’m running a 90 740 Regina with the a cam and I like it. What would you like to know about it?
reed is offline   Reply With Quote
Old 05-09-2018, 10:33 AM   #5
GeneralBurrito
GeneralBurrito's Avatar
The B cam is just a bit better than the A cam on almost every area. I'd just go with the B cam if you can get one for a good price, and if your engine accepts it.
Old 05-09-2018, 10:44 AM   #6
oldschoolvolvo
oldschoolvolvo's Avatar
Some members like to use a “T” cam with n/a + auto due to low end torque and auto not using upper rpms as much as manual can.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 05-09-2018, 10:49 AM   #7
What's the fun in having torque in the rpm range where your car operates?
Old 05-09-2018, 11:16 AM   #8
240240
$600 Volvos
240240's Avatar
What is the top speed you can go in brooklyn?
There is no winning on TB, just losers.
Old 05-09-2018, 11:17 AM   #9
centason
Autogestion
centason's Avatar
Over 100mph. I've seen it. TSB.
Member: TBCCS
"Those who do not move, do not notice their chains." -Rosa Luxemburg
You sons of bitches are the biggest thread de-railers in forum history. Any forums history.
Old 05-09-2018, 11:22 AM   #10
Get the cheaper one. You won't notice a difference.
Old 05-09-2018, 12:11 PM   #11
mrnabisco
mrnabisco's Avatar
Thanks for all the responses.
Interesting about a "T" cam in an auto NA... I was mainly wondering about cam choice with the auto tranny, and trying to get good power/torque inside the auto RPM range.
Reed, how is climbing hills with the "A" cam?
I have come to like the auto tranny in ways, but what I find frustrating is going up hills and not really being able to match rpms and gear to get a good "pull". Uphill the auto tranny always seems to be in either too low or too high a gear. ??? With a strong motor (V15 or VX cam) and 5-speed I could climb hills much better.
And yes, you can go quick in Brooklyn. Maybe not 100mph easily. I've gone pretty quick more than once on the BQE. But I mostly use my brick to go on road trips out of NYC.
Old 05-09-2018, 12:19 PM   #12
oldschoolvolvo
I don't have any personal experience w/ T cam + n/a, but here is some reading:
https://forums.tbforums.com/showthread.php?t=305342
https://forums.tbforums.com/showthread.php?t=198184
Old 05-09-2018, 04:13 PM   #13
240240
$600 Volvos
240240's Avatar
I do t cam advance 4* with cam gear on an autotragic. It's the only way to get smilepower from buttdyno.
I also like to pull treestumps on the 3.73 rear
Old 05-10-2018, 03:24 AM   #14
mrnabisco
mrnabisco's Avatar
Thanks for the links.
I already have an "A" cam, so I'll start with that.
Old 05-10-2018, 05:23 AM   #15
reed
reed's Avatar
With my A cam I have the ipd adjustable gear at 2.5 degs advanced. I’m running 208cc yellow injectors out of a 960. On 89 octane I’m making 90whp and 100wtq with afr 14.7 all the way across the rpm. I’m working on trying to richen my afr to 12.5-12.8. I’m also running the eBay 2.5 turbo exhaust welded to my stock na downpipe. 4.10 rear and Pegasus 17” wheels
Old 05-10-2018, 07:31 AM   #16
reed
reed's Avatar
If you send me a picture of the Regina control unit I may be able to tell you if it has had the factory software upgrade. If not it makes a huge difference in drivability. I can do the upgrade for you also.
Old 05-10-2018, 08:04 PM   #17
mrnabisco
mrnabisco's Avatar
Thanks for the suggestion. I'll get a pick of the Regina unit and be in touch.
Old 05-11-2018, 06:26 AM   #18
Beep beep zip tang
I wish I'd known about your shop last year, I came down and camped at hickory knob state park for the eclipse. I would stopped by to shoot the breeze.
Old 05-11-2018, 09:04 AM   #19
reed
reed's Avatar
I always welcome visitors at our shop.
Old 05-12-2018, 01:50 AM   #20
Tentshedtrev
Tentshedtrev's Avatar
Put the t cam in a 245 wagon, na, auto. Would maintain 110km/hr up most hills with 4 passengers, I was impressed. That's it tho, not much point in revving it out or trying to go much faster...it got a m46 and a k cam shortly after.
Life is too short to stay redblock..
09' C30 m66 t5 R-design (the nice one)
1990 740 SE, Eaton m90 supercharged theb230F drift car *parted and crushed*
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 Vortec 5.3/ar5 trans/8.8 diff, longtubes, intake, sloppy stage 2, BMW front suspension, dual calipers,
1981 242 VW 1.6Td, tracker transmission, k24, fmic, 2.5 exhaust
Tentshedtrev is offline   Reply With Quote
Old 05-14-2018, 04:00 PM   #21
Ryan_R
A is a better driver, but B is better than nothing. B has more overlap, so you'll need to get the revs up before you get "on the cam". T is a utter waste with an automatic.
With an A or B, get an adjustable timing gear and advance 4 degrees at the crank. All the bottom end torque you'd get from an M or T, but the engine will breathe until redline.
In my '91 745, I've run M, T, A, B and finally a B234.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
2011 XC60 3.2L AWD - Wife-mobile
Ryan_R is offline   Reply With Quote
Old 05-17-2018, 06:07 AM   #22
InTheWhite
InTheWhite's Avatar
I have tryed a lot of Volvo stock cam. With a manual trans i rekommend a VX, and with a auto the T cam.
InTheWhite is offline   Reply With Quote
Old 05-19-2018, 12:10 PM   #23
klr142
Turbo, what?
klr142's Avatar
Clarification: The B is just a bit better than the A cam at high rpm. B has more duration so a weaker bottom end and worse emissions. Considering they’re both factory camshafts, they are both fine and the differences are small. In an automatic car I would absolutely pick an A cam if I had a choice between the two. If it was B vs M cam, it would be the B cam for sure!
T cam is a great budget choice for any stock, automatic equipped car. It has lower duration than the M so it increases your dynamic compression ratio and gives the engine more torque. It ALSO has more intake lift than the M cam!
Climbing hills with the A cam is better that the M cam. The A has basically no downside what so ever, when advanced a couple degrees and only gives up a tiny bit off idle otherwise.
The V15 NA cam was good in my stock auto 244 as well, but did give up some low end. I would have loved it advanced 2-4 degrees though, even with the auto!
The Info saying the T is worse than the M is wrong... T is a faster cam than the M, for sure. It just feels boring because the power and is soooooopo flat. I dropped .3s in the 1/4 mile in a “stock” 87, auto 244. Only “mods” were the hot air intake was open to the front of the car, the ignition timing was advanced(16-18? Can’t remember) and i played with camshaft timing(RETARDED 4 degrees). Oh, tighter valve clearances too(.013”?), in order to maximize the minimal duration and lift. 17.3 to a 17.6 with similar mods and the M cam. In this setup, the T cam pulled ok to 5000rpm and my fastest time was set holding it in 1st gear to at least 5500 rpm.
The T IS worth running in any car that is stock, automatic and used under 3000rpm most of the time. In my situation, the car would launch from a stop faster than most of traffic and get up to speed surprisingly quick without ever going over 3000rpm. Guess what, higher dynamic compression and more ignition advance also help gas mileage...
Old 05-19-2018, 01:16 PM   #24
John V, outside agitator
Cams don't "make moare torque", Engine volume x compression--dynamic compression---= torque>
I've been avoiding this place because of administrative misbehavior going unpunished for years but this 'what cam" thing drives me nucking futs..
Dreaming one limp-dick OEM emissions cam is going to do anything worth a damn and having those dreams reinforced by well meaning members.....fu fu fu fawk.
You want to do something that when you're done you're going to really smile and smile every time you drive your car?
Then pull the head--so simple it is not even funny---and mill the head 1mm/ .040" to 1.4mm or .056-060"
Then get a cam INTENDED to be a fun cam.
Then you'll feel you've done something worthwhile.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 05-19-2018, 01:53 PM   #25
GeneralBurrito
Oh yeah, forgot it was for an auto. Does an A make a difference over a B in an auto? I was thinking about in manuals.
