Old 04-15-2004, 03:32 PM   #1
n xntrx volvo
n xntrx volvo's Avatar
Default low-buck performance mods
speed = money , right?
but lets face it most of us are broke and/or cheap.
post your mods under $50 us.
mine
k&n = 33
resister to ecu on coolant senser = 2
remove belt to a/c & p/s = free
ram air = 18
remove mass air screens = free
what did you guys do?
*all mods should be able to be easily repeated, ie no tools over the $50, no give away parts.
my cars (click me)
I'm not here, Please leave a message after the tone........(or email me).
n xntrx volvo is offline   Reply With Quote
Old 04-15-2004, 03:36 PM   #2
n xntrx volvo
lets also assume a stage 0 starting point, no tip on how you gained 20 hp by doing a tune-up
thanks,
aaron
Old 04-15-2004, 03:50 PM   #3
The Aspirator
It's a girl!
The Aspirator's Avatar
Knife edged my throttle body plate and trimmed those screws....... just cause I was in there, probably didn't gain anything though.. but it was free
K&N - $40
Dual swaybars front and rear- $50
MSD 8.5mm wires - $45
MSD coil - $8.95 after summit newbie rebate!
Turbo fuel system (injectors and computer) for my F+T - $30
531 head and V cam (not in yet) - $20
60/63 ford turbo - ok, so it was $85 at the yard, but worth EVERY penny and can be found for cheaper. It pushes sooo much more air than my old one. 50% larger!
Dual windshield washer squirters from a Saab!!! - $3.00
That's all I can think of that I've done to my car, but I know there are tons more worthwhile mods for under $50.
John
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 04-15-2004, 04:00 PM   #4
n xntrx volvo
also glued the airbox flapper shut = free
sway bar end links = $48? can be homemade cheaper
how did you get a 531 for $20 bucks?
Old 04-15-2004, 04:08 PM   #5
EvanSargent
Board Saint
EvanSargent's Avatar
G-Valve = $43 (I got mine for x-mas so it didnt cost me anything)
Dual stage solinoid = $50 (got it back when they were cheap)
My dad and some wire to make it work like I planed it out = Free
EvanSargent is offline   Reply With Quote
Old 04-15-2004, 04:33 PM   #6
Chigga 744SE
Taiwan hillbilly
Arospeed filter ($20)
heatshiled (free)
um....... I need to learn how to get some cheapo stuff.
Chigga 744SE is offline   Reply With Quote
Old 04-15-2004, 04:49 PM   #7
The Aspirator
It's a girl!
Cause I know where to look and who to ask
I'm curious to hear what other people add to this, it's a good topic especially for newbies. Actually, if we read the guide to newbie mods it'd probalby give us more ideas!
Another thing I thought of:
Electric fan - Free
Adjustable thermostat relay - $20.00
Although not quite performance, it sure cools down a performance engine WAY better than the stock fan.
John
Old 04-15-2004, 05:04 PM   #8
n xntrx volvo
no free parts, no once-in-a-lifetime buys. the point of this thread is so anybody can repeat your mods, for under $50 each, regardless of/lack their connections, and their location.
Old 04-15-2004, 05:53 PM   #9
kyle242gt
Still has a Volvo
kyle242gt's Avatar
My NA mods-
A Cam - $40
advanced timing - free
removed front piece of air snorkel - free
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
Originally Posted by alschnertz View Post
Please leave the "what should I do" threads to Kyle.
You're out of your league.
I killed a 5.044!
kyle242gt is online now   Reply With Quote
Old 04-15-2004, 06:12 PM   #10
EvanSargent
Board Saint
Jumbo Brakes complete (new pads and disks w/ used calipers) = trade for my power grove big brake rotors.
Old 04-15-2004, 06:52 PM   #11
sweetswede
sweetswede's Avatar
Aluminum Amm To Turbo Pipe, Like $30 Bucks. Cut To Fit From A Honda Civic Intake Pipe. You Should Hear The Cbv!!
sweetswede is offline   Reply With Quote
Old 04-15-2004, 07:02 PM   #12
Chop off rear muffler-Free
Tighten wastegate- free
remove airbox foam- free
remove amm screens - free
remove 20lb frame weights- free
Remove AC condensor from in front of IC- free
remove AC belt- free
remove 45lb third seat- free
remove 10lbs worth of under carpet sound deadening- free
deflate rear tires slightly for traction- free
ghetto cold air intake (i use stock box and paper filter. Ran the same times at track with no filter)- free and up
tighten downshift cable- free
Im thinking too hard. Bye
Old 04-15-2004, 07:07 PM   #13
get rid of preheat hose- free
elec fan- 25$ at yard
torque manifolds/change gaskets/fix air leaks/tune up- free to cheap
flowmaster and k&n stickers- j/k
Old 04-15-2004, 07:40 PM   #14
Al
Dang you guys hit most of the good stuff. But no one got these goodies.
Air box mod. That is where you pull the restrictive cone extension that runs inside the tube to the fender (Free). Fill the Motor, Transmission, and differential with Synthetic lubes. I have Mobil One in the motor, Redline MTL in the transmission, and Redline 75W90 in the rear end ($55). This should free up 4 to 8 HP lost in the drive train from drag and friction.
When was the last time you cleaned the oil out of the intercooler and hoses (Free) Cleaned the TB?(gasket $3) How old are you plugs and wires? Air cleaner Clean? When was the last time you went through the car and got rid of all the junk you really don't need out of the car. (Weight reduction) (Free) Have cleaned the Bugs and road garbage out of your Condenser, Radiator and IC? Air flows through easier and makes all three more efficient at cooling (Free) Also make sure the splash shield underneath is intact for better air flow.
Go through the exhaust system and make sure there isn't any leaks from the exhaust manifold to the tail pipe. And yes it does matter other than more noise.
If the car isn't in tune your losing power to start with. And lastly you could Auto-RX the engine to clean all the built up garbage inside the engine out. And yes it does free up power that has been lost to stuck rings and sludge on the moving parts. $55 And yes your engine will love you for it. Info available at www.bobistheoilguy.com or www.auto-rx.com
Al is offline   Reply With Quote
Old 04-15-2004, 09:41 PM   #15
ovlov760
ovlov760's Avatar
lose both mufflers and the cat
Old 04-15-2004, 10:53 PM   #16
volvo944ti
if you got a 89 or earlier 740 hunt the junk yards for a alluminum hood- make friends at the junkyard cause you mght be able to grab one really cheap
grab a t3 metal 90 degree turbo bend and the metal pipes from a 90 plus intercooelr hack to fit. almost all metal turbo to intercooler pipes.-what like 20 bucks at a junk yard
hunt aroudn for a good alluminum pipe 90 degree bend at junk yard- go to home depot buy rivets and a piece of sheet metal(alluminum is always best) bend and cut to look liek the mvp style heat shields. then instead of having all those bends for turbo to amm hose just use that alluminum 90 degree or so to the base of the heat shield locate your amm there on a mount. wow you've just gotten rid of like over 200 dollars of rubber hoses. what like 30 bucks and 50 with a cone filter from autozone.
and were are the 20 lb frame weights that can be removed????
volvo944ti is offline   Reply With Quote
Old 04-16-2004, 02:34 AM   #17
Slobodan
Slobodan's Avatar
Got M or L cam's on your N/A B21 / B23? Go B cam for as little as 10$ from the junkyard.
and another 10$ for a E-Fan, plus $14 for a thermal Switch, and the plastic hose coupler to mount the switch in - .69 cents. whack and hack your exhuast I believe this has been mentioned.. what else did I do for mods that was cheap? when to a newer 530 head over the not so different 398 head. doubt that helped power but its newer and less worn out than my 398. Using a IC pipe to intake from 760 Turbo for custom metal cold air intake mod is in the works. I'll just need the cone style air filter, 20 bucks from Matrix. Bosch plus 4 spark plugs - helps out gas milages alot! New O2 Sensor.. but these aren't really mods.
hmm... meh... Remove all your interior but the drivers seat? ??
'85 744 GLE: D24TIC ZF 22. Current DD.
'79 245 DL: D24TIC M47 40mpg:
'79 242 GT: B21FT K-Jet 24.4mpg
'72 164 : B30 M410 Needs front end work.
'83 265 GL : D24 M46 - Must complete the maintenance
Slobodan is offline   Reply With Quote
Old 04-16-2004, 02:51 AM   #18
EvanSargent
Board Saint
Pretty much anything stock with a block mount distributer should benifit from a B cam I have heard that B23ET's had them as well.
Old 04-16-2004, 06:28 AM   #19
byte1032
damn it has to be under 50$. how about getting a car for like 300 with cut front springs, (nice handling) intake and vx cam and rebuilt head already intalled. still havent spent any real money on the car, thanks to friends. that ecu helps soooo much slobo thanks. ohhhhh here is something i want to try and it will be under 50, how about like 3 bottles of octane booster to go with our bullet proof engines. hah. ok maybe just 2 but still. oh and bosch quads are great
byte1032 is offline   Reply With Quote
Old 04-16-2004, 06:42 AM   #20
The Aspirator
It's a girl!
Octane booster is bull-honky. Toluene is where it's at. You get like 5 times more for the same price. Search for it.
Manual boost controller - made my own for just over $10 with parts purchased from mcmaster.com. Works great!
Cams are a really good improvement too, basically anything other than M or T.
John
Old 04-16-2004, 12:00 PM   #21
boosted
boosted's Avatar
Default ...
60/63 turbo - $20 from the junkyard
removing weight from various places - free
electric fan - $5
adjusting timing - free to cheap
cone filter - $20 from any store, $5 for my K&N
cutting the exhaust - free
3" exhaust setup from napa - $50
-1998 V70r AWD
boosted is offline   Reply With Quote
Old 04-16-2004, 01:35 PM   #22
kenneth rigney
kenneth rigney's Avatar
Default Alcohol
The best mod I ever put on my 1979 242DL, was a water/alcohol intake vacuum feed bottle.
My dad told me about it, we made it ourselves, this was so easy. get some plastic brake line (i used aquairium tube the first time), a $8 breather filter from autozone, a oneway vacuum valve that fits the tube you use (Toyotas are full of them, 10 cents in a junkyard), and a plastic or metal bottle you can fit with some fittings and seal tight. fit the bottle so that the breather tube is at the bottom and the sucking vacuum tube is above the fluid level, run this to your intake manifold, and the engine will do the rest. I have a '82 fully rebuilt B21, VX cam, accel super coil, custom cool air intake, and the water/alcohol vacuum feed was the best thing I did, the car runs smoother, You can tell the differce. This should work on any n/a red engine.
kenneth rigney is offline   Reply With Quote
Old 04-16-2004, 05:16 PM   #23
n xntrx volvo
anybody got more info, or links to this? don't know if it would work well with ram.
Old 04-18-2004, 09:19 PM   #24
kenneth rigney
Question don't know if it would work well with ram?
? the water/alcohol should work if your manifold draws vacuum, I have seen web sites for these things, but, it is so simple, finding a bottle is the only hard part, type "water injection" in a search engine. The one I use has no moving parts and uses engine vacuum only.
peace
Old 05-16-2004, 06:58 PM   #25
fengler
fengler's Avatar
what exactly does that do? also g-valve = mbc right?
Current-2006 Toyota Highlander Hybrid (190k)
Current-1967 Volvo P1800
Fengler would totally smash.
Originally Posted by regina745ti View Post
lext nevel hengler maneuver
Originally Posted by resa850
Nick: I love you.
Originally Posted by CaptainLeah View Post
I saw fengler was the OP and I knew it was going to be gold.
"Without music, life would be a mistake." - Nietzsche
fengler is offline   Reply With Quote
