Old 05-27-2014, 06:20 AM   #1
mark244turbo
mark244turbo's Avatar
Default stripped / rounded / sheared wheel nut
Someone overtightened the wheel nuts of my 740. I got most of them loose by jumping on a wheel wrench, but one bolt won't move a bit. I tried an extension bar, impact wrench, heat..but without succes. And now the nut is stripped / sheared or rounded.
Any suggestions on how to remove a stuck rounded wheel nut?
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 05-27-2014, 07:38 AM   #2
swiftjustice44
Central Coast Brickyard
swiftjustice44's Avatar
Cut it off. Impact hammer, die grinder, cut off wheel....whatever it takes. You'll need a new stud of course.
swiftjustice44 is offline   Reply With Quote
Old 05-27-2014, 09:25 AM   #3
smokeyfan1000
Guest
FWIW....
You do know that it's a *METRIC* lug nut on 740s.....right?
I say this because many presume it's same as a 240 lug nut but it *is not* a 1/2-20 stud with 3/4" socket size lug nut like on a 240.
Hence many inexperienced owners/tire guys use a standard 3/4 (or 13/16th if been changed ) lug wrench on the 740's lug nuts thus rounding them off
Old 05-27-2014, 11:15 AM   #4
benski
Post
You MAY be able to take a Dremel and cut the nut off the stud and leave the stud in place. A faucet wrench or pipe wrench may get it to loosen up, Failing all that, yep you're in for a new metric stud and proper lug nut. No matter what, I'll bet you'll be very careful about who works on your tires and wheels.
Old 05-27-2014, 12:19 PM   #5
mark244turbo
i am aware the nut is metric nut (19mm), i used the proper socket.
Cutting the nut off is not really an option. The nut sits completely embedded in a polaris rim, and i don't want to damage the rim.
I think the guy doing the MOT overtightened the wheel nut or used an impact tool. All nuts were really tight, but finally gave way, except this one.
I rounded the nut when trying to free it with an extension bar.
Old 05-27-2014, 12:25 PM   #6
Lando
Arthur Digby Sellers
Lando's Avatar
Get a cheap twelve point or spline socket that is just barely too small to fit on your rounded nut. Pound it over the nut using a large ball-peen hammer. Hit it with a bigger impact or longer cheater pipe.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is offline   Reply With Quote
Old 05-27-2014, 12:26 PM   #7
thelostartof
unbalanced chemical
thelostartof's Avatar
Remove the wheel bearing/hub.... Once removed you should be able to cut off the stud and press out /drill out from the back side. You might or might not have to take the brakes off also.
Otherwise weld on or hammer on wasted socket and go from there.
Old 05-27-2014, 12:26 PM   #8
swiftjustice44
There's no magic cure that I know off. It has to come off. Perhaps drill with successively larger bits until the nut can be broken. If you can make the hole large enough, a cold chisel will eventually split it.
Old 05-27-2014, 12:35 PM   #9
D.E
tvåförti
D.E's Avatar
Maybe make a mark with a chisel in the stud and drill it out? When you've drilled with a big enough drill bit past the nut you should be able to break it off. Then pound the remains of the stud out and replace it.
'88 Volvo 245 - LH2.4, M47
'20 Volvo V90CC - D4 AWD
'64 Ford Taunus 17M, '78 Fiat 126P
D.E is offline   Reply With Quote
Old 05-27-2014, 05:48 PM   #10
745 TurboGreasel
745 TurboGreasel's Avatar
get some penetrating oil on there
take a deep socket that fits over the stud , and set it against the offending nut.
Now with a 3-4 LB hammer hammer that socket toward the wheel.
Hit it hard for about 20minutes, and the nut will get loose.
Then like Lando suggests, hammer on a socket that doesn't quite fit, or an extractor.
Feedback
Old 05-27-2014, 06:17 PM   #11
Mueller
Mueller's Avatar
A hardened non-plated socket designed for an impact gun might work better and usually resist splitting like the chrome plated units.
Old 05-27-2014, 07:14 PM   #12
mopar318
mopar318's Avatar
Lug but extractor should work. Short burst with the impact will do wonders.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 05-28-2014, 01:29 AM   #13
gtlover
One Weird Old Trick
gtlover's Avatar
I've got a set of extractor sockets that have bailed me out of situations like this, works like an easy out. An easy out might work in this case as well.
If you smoke after sex,
use more lubricant.
00 V70R "Tusenårsfalken"
09 Volvo C70 T5 "Old Blue"
11 Honda Odyssey Touring "Penelope"
85 Volkswagen Westfalia "Scout"
80 Dnepr MT-10/36 "Jenny"
09 Genuine Buddy 150 Blackjack "Jack"
78 Honda CB750F Supersport
volvo_bass@hotmail.com
gtlover is offline   Reply With Quote
Old 05-28-2014, 01:45 AM   #14
Jack
junkman
Jack's Avatar
weld on a bolt
the heat will loose the rust and it should come off easy
I love you even more Jack.
Old 05-28-2014, 04:09 AM   #15
mark244turbo
Wow....thanks guys....thats a lot of methods to choose from.
Old 05-28-2014, 08:48 AM   #16
Beep beep zip tang
Grab wheel rock back and forth until stud breaks, replace.
Old 06-07-2014, 10:35 AM   #17
mark244turbo
I bought an wheel nut extractor set. Hammered the socket on the nut and was able to free it with a long bar.
Now i only need a new lock nut.
Problem fixed!
