Old 11-29-2014, 12:00 PM   #1
v8volvoman1
v8volvoman1's Avatar
Default 3" flexpipe for downpipe
I was wondering what folks have been running for a weld-in flex pipe on their turbo Volvo. I bought a cheap 2.5" diameter flex pipe about three months ago and it has already blown out. Tell me what has worked for you (diameter, brand, mileage since exhaust was built, etc.), how long you've been running with it and what hasn't worked for you.
I need something more robust that's a weld-in application. I have a 3" downpipe reducing into a 2.5" and would like to extend the 3" a little further.
1997 850 GLT
Feedback page: http://forums.turbobricks.com/showthread.php?t=61124
v8volvoman1 is offline   Reply With Quote
Old 11-29-2014, 12:06 PM   #2
jao
in my experience they are not needed on our cars.
-jesse
1971 142e 16v/MSNS/m47/18" Kinesis K20s etc
1988 244dl 16v+T/18" HREs/ corbeus / MSNS etc
"...i often drift when i drive..." - the ghetto boys
jao is offline   Reply With Quote
Old 11-29-2014, 12:55 PM   #3
JW240
All idiot, no savant
using a cheap-ish (35 euro) 3" flexpipe right behind the catalytic converter. Has been in use for 5 years now without issues. Only a bit rusty now. The damage is from some scrape on traffic bumps.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 11-29-2014, 01:08 PM   #4
Dicktater
Cretin
Dicktater's Avatar
I bought this about five years ago and it's still there......I didn't use clamps, welded it on.
http://www.jegs.com/i/JEGS-Performan...oductId=831438
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 11-29-2014, 08:00 PM   #5
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Try mandrel bend solutions. You want a flex coupler with a rigid interlocking liner. The cheap braided inner / outer develop a significant restriction over time as the inner braiding will swell inwards. Anyone who believes otherwise is fooling themselves.
Just used one of their 3" on my DP - I cut the external later of woven braiding off due to interference fit with my firewall
Old 11-30-2014, 02:37 AM   #6
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I've used the ones from atpturbo on multiple builds for years with out issue.
Old 11-30-2014, 09:05 AM   #7
v8volvoman1
Excellent feedback guys. Thanks!
Old 11-30-2014, 01:24 PM   #8
Canuck
Frozen Garage Hell
Canuck's Avatar
The flex pipes I use for builds are lined...they look like the cheap ones, but won't blow out. Make sure to check - they look the same.
Old 11-30-2014, 01:49 PM   #9
lummert
lummert's Avatar
Why would a flex pipe be needed on a RWD car? I can understand why one would be needed on a FWD car.
Old 11-30-2014, 02:09 PM   #10
Dicktater
Cretin
Dicktater's Avatar
As you can see in the pic above the down pipe is secured to the engine, that leaves the rest of the exhaust going out the rear of the car (lots of weight) only supported with a few rubber hangers that are going to bounce around a little.
They may not be needed but it's cheap insurance to avoid cracking a manifold.
Old 12-03-2014, 03:23 AM   #11
gtlover
One Weird Old Trick
gtlover's Avatar
Having sold the big boy versions of these for marine and industrial diesels for about ten years, I've learned a few things.
First, you want to make sure it's an actual bellows, not just metal flex hose; bellows will take axial as well as lateral movement. Second, it's just meant to take up vibration and movement, not misalignment. And it can only move so far. Third, torsional stress will kill these quick - and it will split lengthwise like a zipper. If in doubt, two bellows at 90 degrees to each other will have near universal movement.
Oh, and that braid on the outside? When properly engineered, it helps damp out vibrations. Totally unnecessary for holding exhaust pressure.
If you smoke after sex,
use more lubricant.
00 V70R "Tusenårsfalken"
09 Volvo C70 T5 "Old Blue"
11 Honda Odyssey Touring "Penelope"
85 Volkswagen Westfalia "Scout"
80 Dnepr MT-10/36 "Jenny"
09 Genuine Buddy 150 Blackjack "Jack"
78 Honda CB750F Supersport
volvo_bass@hotmail.com
gtlover is offline   Reply With Quote
