![]() hello
I was wondering if any volvo center caps will properly fit the eiker wheels? if so maybe a part number? thanks |
![]() I don't think they are will fit. Do you happen to have a picture or the part number for that wheel so I can check into it for you?
ドクターマリオ
![]() The ones you want are from a gen 1 S40 or V40. Like so: http://www.ipdusa.com/products/6982/...er-cap-s40-v40
They don't fit perfect as in they can wiggle a bit in there, but they're solid enough to not go anywhere. Installed they look like so: ![]() |
#4 |
![]() much thanks to you guys.
#5 |
![]() Bumping this 8 year old thread... yikes! I ordered myself some OEM center caps from the link above through Ipd (PN # 30638643) but they are way too small. Like they won’t even sit in there.
Does anyone know the correct PN? Hoping to grab a set from the local dealer or Ipd again. Thanks, Sina
2009 Toyota 4Runner SR5 4WD - Inefficient Daily 1991 BMW 318i E30 - Reborn & Re-shell Project 1983 Peugeot 505 STI - Weekend Cruiser 1992 Volvo 245 Euro spec'd |
#6 | |
Dejected by Volvo
![]() Quote:
Here are some common Volvo caps with dimensions and what hole they fit. The one that DOESN'T fit is the middle one. If anyone can help add to this info, let me know. https://www.prancingmoose.com/center...tml#commoncaps And when you figure it out, don't be like all the others who figured it out who won't let the secret out. Come back here and offer some info. Dave B
![]() '84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80. Volvo Ambivalence of Volvo Enthusiast Community: prancingmoose.com/#novolvo Dave's Volvo Page: davebarton.com 240 Mods and Fixes Pages: 240turbo.com/volvo240mods.html |
#7 |
![]() Came across this thread while researching for replacement caps or emblems. I recently bought a used set of Eikers that came with center caps number 3529610, which is the discontinued one that fits well. The logos are just faded on my set.
Eiker center bore I measured as 56mm Center cap 3529610 also measures 56mm, and about 57.5mm across the retaining tabs. Metal Volvo emblem on front is 60mm
1979 244 Manual 2.5 Penta Turbo |
#8 |
Porkchop Sandwiches
#9 | |
Dejected by Volvo
![]() Quote:
Dave B |
#10 |
Porkchop Sandwiches
![]() I said the best ones I found, not the best ones ever made. I don't think that any of them are perfect, but there are several that are usable. The ones mentioned above have stayed in the wheel for over a year now.
#11 |
![]() I went on ebay and found generic 60mm center caps. They were about $12/set shipped. Available in both silver and black, they have a hole in the middle, and a metal retaining ring on the back for tension. It looked like multiple sellers offering the same ones. The listing said the clips in the back were 58mm across, so it was worth a test. They actually fit really well. The first install seemed tight, so I removed the metal retaining ring and reinstalled. It would work with or without it. Looks like they would fit a 57mm or 58mm decal in the front since there is a lip around the edge. Time will tell if the plastic cracks quickly
#12 |
![]() Given I have a set of genuine beaten up Polaris wheels and the original UV damaged dirty crusty 3529610 caps, I thought I'd crack out the Mitutoyo dial calipers and put some EXACT sizes in this thread. Pics:
Cap: Display section OD: 59.20mm Spigot fit stepped OD: 58.65mm Lowest OD between clip and face: 56.40mm Accurate and repeatable to 0.01mm! And the wheel, it was a bit trickier to measure, but I sacrificed my old cheap set of calipers for the cause: Pics of wheel measurements: Wheel cap bore sizing: Outer ID: 59.00mm Inner ID: 57.00mm ^ trickier to measure with junk tools and corrosion and paint/powder coating etc, but got there in the end. Plus/minus 0.1mm on those, though. Also note that those figures are without paint/powder coating - I should measure another wheel with the coating still on it to see what the size is in that form - you can bet the caps are engineered to suit that. Actually, went out and tried to check and not much difference, or already worn off, or replaced with oxidation etc. Cap was a more snug fit before I cleaned the junk out of there. Oh well. If Kurt NY mreaured the Eikers correctly then they're different to the genuine Polaris wheels or at least my measurements thereof, and actually a better fit for the V40/S40 ones. Given the V40 style ones have an OD of 60 and a small taper behind that leading to the 55mm necked down section, and the spring clips look to be about 60 in their extended position, I'd say provided the depth is okay they'd work fine. To guarantee a snug fit inside the 57mm bore 1mm of plastic shim could be glued to each clip low section. OR you could have your bores machined up to suit the slightly larger caps. Side by side about as well as I can do without buying any yet:
FreeEMS.org - the open source engine management system My Volvo Adventure (No 56k). My non-Volvo turbo truck. My gold 1991 240 wagon! My blue 1990 740 16v sedan! |
