Old 11-25-2017, 07:33 PM   #1
thelostartof
unbalanced chemical
thelostartof's Avatar
Default Guess that noise
I just got the car running again after snaping a TV cable for the trans. First test drive around 10 miles into the drive and this happens. Go figure, I never went over 9psi so who knows what went wrong this time. Engine definitely is down a cyl so we shall see if I can find some time to tear into it tomorrow.
Old 11-25-2017, 07:38 PM   #2
EivlEvo
oof
Old 11-25-2017, 10:08 PM   #3
centason
Knipex=welfare queen
centason's Avatar
Sounds like its right under the valve cover. Flick a shim out?
Member: TBCCS
"Democracy is a pathetic belief in the collective wisdom of individual ignorance.” -H.L. Mencken
Old 11-25-2017, 10:09 PM   #4
sbabbs
sbabbs's Avatar
Bad rod bearing.
1988 245 White slicktop M47 Wagon! Motor still out of it.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K Melted motor..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 11-25-2017, 10:23 PM   #5
2manyturbos
Unfortunately, I agree. I have had 2 B230FTs lose a rod bearing and they sounded Exactly like that.
Old 11-25-2017, 10:36 PM   #6
centason
centason's Avatar
Hmmm... interesting. Though, I've never had a rod bearing go on a redblock. Toyotas have more of a thud sound. Damned engine acoustics.
Old 11-25-2017, 10:38 PM   #7
2manyturbos
I tried real hard to convince myself it was something else. When I pulled the head I could move the piston down .020" before it stopped by backing the crank up first.
Old 11-25-2017, 10:42 PM   #8
centason
centason's Avatar
Understood. I'll know what to listen for. Not something I'm wishing for
Old 11-26-2017, 12:13 AM   #9
thelostartof
unbalanced chemical
Well the good news is that the clacking has stopped, the bad news is that is it still firing on only 3 cyl, oddly enough cyl number 3 is dead, pulling the injector plug or coil does nothing.
I am trying to decide if I want to throw the rods i have in the n/a block sitting on the engine stand or if I want to try to do something a bit more extreme and then what block to use. In a month or so I will have a second 1993+ n/a block available. But this is the perfect winter weather to be driving a turbo car not working on it.
Old 11-26-2017, 12:15 AM   #10
gsellstr
gsellstr's Avatar
Almost sounds too fast for a rod knock, knowing what mine sounds like with slap. Double-checked the flex plate hardware yet? I'd also expect a tone change between throttling up and winding down (based on experience, having lost a couple rod bearings in mine). Strange...
sure...reply WHILE I'm typing...
How's the oil pressure? Vacuum stable? More blowby than before?
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-26-2017, 12:35 AM   #11
Cwazywazy
Single jingle
Cwazywazy's Avatar
Have you done a compression test?
I don't know what I have
Old 11-26-2017, 12:39 AM   #12
thelostartof
unbalanced chemical
Oil pressure was rock solid in the sense that the oil light never came on, I was about 1 qrt low in terms of oil was at the bottom of the dipstick mark. I will try to pay attention to vac maybe if I start it back up again. Vac has always been 11-13 on this engine. No smoke out the tail.
Either way I will pull the plug for #3 tomorrow and see if I can get my scope in the hole and see what is going on. I guess I might also be draining the oil to check it. The dipstick and oil in VC looked fairly clean.
While I am hoping it is the head I almost want it to be the block and the head is still good, either way lots of taking it slow tear down in front of me and $ to be spent. Great time for a fresh block, new exhaust manifold and new turbo along with all kinds of other stuff right? Or maybe just another block so it drives, turn the boost down and V8 swap the 944 and then V8 swap this once I know what I am doing and then add a turbo. Who knows what tomorrow's mood will put me in.
Old 11-26-2017, 12:55 PM   #13
bobxyz
bobxyz's Avatar
Slipped valve guide?
Old 11-26-2017, 01:17 PM   #14
photoman327
photoman327's Avatar
Following but had a Sbc sound like that and I thought rod but it was the cracked flex plate.
Old 11-26-2017, 05:38 PM   #15
gsellstr
gsellstr's Avatar
Heard similar to ^^^^ as well. Brother got blamed for it on the parents van until they found a bolt had backed out of the converter. lol
Old 11-26-2017, 05:48 PM   #16
2manyturbos
That could be it. My Camaro did the same thing. Chewed the heck out of the flex plate and the sheet metal inspection cover.
Old 11-26-2017, 07:46 PM   #17
thelostartof
unbalanced chemical
Well the issue might not be a lower end issue . . .
But either way it looks like I will need a full long block worth of work to fix this one, and depending on my luck a turbo also if it damaged the wheel exiting the engine.
Old 11-26-2017, 08:01 PM   #18
2manyturbos
Bummer. It definitely sounded piston/rod related to me.
Old 11-27-2017, 09:12 AM   #19
Good Knight
Good Knight's Avatar
Valve guide!!! It comes apart when is slips down. Had it happen twice on a 530 head I had a lot of time and money invested in.
Run a pool called name that tune!!!
Good Knight is offline   Reply With Quote
Old 12-10-2017, 12:15 PM   #20
thelostartof
unbalanced chemical
Source of noise found, screw for the throttle plate. I guess there is a first time for everything, first time I have seen this as a failure on these engines. Broken in two places.
And the damage
Yes that is the threaded part of the screw there.
Old 12-10-2017, 12:22 PM   #21
mocambique-amazone
Never seen a broken shaft, lost srews for throttle plate a few .
The head was gone too, if the piston rings are still free and not blocked by the damage you can run them still.
Had seen worse still running.
good luck, Kay
Old 12-10-2017, 01:28 PM   #22
Sweep
Ooer, has the TB been apart before?
Old 12-10-2017, 01:34 PM   #23
doleary
thats an awful way to bust a motor ( as if there is a good way ), anyways best of luck man.
doleary is offline   Reply With Quote
Old 12-10-2017, 02:25 PM   #24
thelostartof
unbalanced chemical
As far as I know the throttle shaft has never been apart. And a very sad way for a 531 to die along with and engine. The block looks like it should still be good. I am hoping a quick hone might remove the small mark on the bore otherwise it might be getting bored out for a rebuild far into the future. Now to put together the H beams I have here into my spare na block.
Old 12-10-2017, 02:50 PM   #25
MrD
It will buff right out
MrD is offline   Reply With Quote
