Old 07-20-2018, 03:16 PM   #1
Fa182
Stage 1
Fa182's Avatar
Default 940 KL Racing intercooler
I just wanted to make some comments on the KL Racing intercooler for 940 for future searches. Never actually came across a proper field report, so I thought it wouldn't hurt. Installed on the car today in less than 30 minutes.
Upon inspecting, the welds are very well done, very shiny thing. Just because I read some comments that it might be the same unit as the do88 just without the embossed logos, it's definitely different. The middle section with the fins does look very similar though, or at least similar design.
Weighs around 10kg, much more than the stock IC. The fit was perfect, just had to shave a bit off of the rubber inserts on the brackets because of the increased thickness (60mm) and drill some new holes in the brackets.
The first test drive was amazing, I couldn't believe what huge change it made. Throttle response is much faster, boost increased by around 0,15bar (or roughly 2 psi) without touching the MBC and I have a loooot less turbo lag from 2k-3k rpm. I feel a huge improvement in torque, especially in 3rd gear from 80-120kmh (50-75mph).
Temperature on the intake side is much lower now. After driving with lots of boost, I almost couldn't touch the stock IC on the intake side because it was so hot, the KL unit is just lukewarm.
Don't have any experience with the do88 unit, but I can't imagine it will be much more improvement over the KL and for half the price (254€ KL vs. 490€ do88), you can't really go wrong.
NPR IC is obviously another choice but those are like unicorns to come across around here in Austria, so I just ordered from KL. Ordered in Sweden on Tuesday, arrived today on Friday. KL is awesome.
When I upgraded the turbo from 13C to 16T, the result or increase in power / torque was quite disappointing and I think the IC was the culprit.
1997 945 Turbo, 16T, TLAO chips, 12psi boost. No AC, so top mount IC.
https://shop.klracing.se/sv/artiklar...n-ac-60mm.html
Old 07-20-2018, 03:49 PM   #2
soclosenotnear
Great review. I had about the same experience when I installed my do88. I would tend to agree with you though. Had I known about the kl racing unit, they'd have gotten (half) my money. It seems to be the much better deal.
check my feedback here
Old 07-20-2018, 04:15 PM   #3
PCH
So the inlet/outlet is on very top (that's how the picture shows it) instead of the center? Did you change the IC piping too?
Old 07-20-2018, 04:35 PM   #4
Fa182
Stage 1
Fa182's Avatar
My stock intercooler is like that because I have no AC. It uses different piping, the non-AC IC has the outlets on top. They have both versions, just like do88.
AC https://shop.klracing.se/sv/artiklar...-ac-60mm-.html
Non-AC https://shop.klracing.se/sv/artiklar...n-ac-60mm.html
Old 07-20-2018, 05:33 PM   #5
PCH
Thank you for explaining this. Didn't think there were non-A/C 940's.
Old 07-20-2018, 05:57 PM   #6
Fa182
Stage 1
Fa182's Avatar
Yeah I think there were more non-AC 940's around here than in the US. AC was usually not equipped as stock on most cars here back then.
Old 07-21-2018, 03:13 AM   #7
OttoB
I found interesting Dyno tests at Sävar. A, T and K can comparison and Stock Vs KL cooler
http://forum.savarturbo.se/viewtopic...f7da0b7016a6f7
Old 07-21-2018, 08:45 AM   #8
mark244turbo
mark244turbo's Avatar
Great review. Nice to hear your intercooler makes suchs a big difference.
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 07-24-2018, 03:34 PM   #9
ogamer777
Loading...
ogamer777's Avatar
Very nice. Looks like I've found my next purchase ��
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 07-24-2018, 03:40 PM   #10
Cwazywazy
Single jingle
Cwazywazy's Avatar
I have the same one in my 240, great improvement. Almost a drop in replacement. Plus it's shiny. My butt dyno isn't very well calibrated, but I felt a definite improvement throughout the revs. Boost jumped 1psi after installing.
I don't know what I have
Old 07-24-2018, 04:00 PM   #11
soclosenotnear
What makes the bump in boost? I don't remember my pressure increasing but it was a while ago.
Old 07-24-2018, 04:07 PM   #12
oldschoolvolvo
oldschoolvolvo's Avatar
Less pressure drop...aka more flow.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-24-2018, 04:08 PM   #13
Fa182
Stage 1
Fa182's Avatar
Because they flow much better than stock. do88 has some diagrams on their site and it should be comparable with the KL I guess.
https://www.do88.se/en/artiklar/volv...tercooler.html
Old 07-24-2018, 04:13 PM   #14
SquareD
An Anomaly
SquareD's Avatar
Maybe you took the inlet/outlet caps off too early and let all the extra boosts out?
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 07-24-2018, 05:13 PM   #15
Sjeng
Sjeng's Avatar
Swapped in 24x12x3" chinese/"ebay" intercooler today. Also 0.2 bar more boost than stock 940 IC.
Had to cut some metal from the car to fit the elbows and had to fab up new piping.
Still running AC condenser and everything.
Old 07-24-2018, 05:15 PM   #16
Sjeng
Sjeng's Avatar
Most of us measure the pressure at the intake manifold.
If there is less pressure drop over the new intercooler (less restriction) you will measure higher manifold pressure, while the pressure post compressor is unchanged.
Old 07-24-2018, 10:42 PM   #17
gsellstr
gsellstr's Avatar
I saw a similar pressure increase at the manifold when I swapped from the stock to the NPR. Didn't see a drop when I swapped the NPR for the do88 though.
Thanks for the review on the KL, good to hear from someone that has one.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-24-2018, 11:08 PM   #18
cosbySweater
cosbySweater's Avatar
The one thing that I do personally like better about the more expensive do88 is the cast end tanks. I have no experience with either of these as far as a redblock goes but I did recently change to a cast tanked intercooler in my car and felt the smallest difference but a difference none the less when I switched from a sheet metal eBay ic to a treadstone
1995 Porsche 993
2013 VW Passat TDI
Old 07-25-2018, 07:51 AM   #19
Acke
Acke's Avatar
The end tanks are cast in the KL cooler as well. And I agree with Fa182:s comments on the cooler, fits and works nicely. I didn't have to drill any new holes in the brackets, just extend the old ones 2-3mm. The rubber has to bee trimmed on both upper and lower brackets.
One negative aspect is that you have to slightly move or pull out the cooler when changing the air filter.
Old 07-25-2018, 03:32 PM   #20
seads505
seads505's Avatar
What was the cost of shipping to the US? Was there any special process you had to take during checkout, or did you call them and order?
seads505 is offline   Reply With Quote
Old 07-25-2018, 03:50 PM   #21
ogamer777
Loading...
ogamer777's Avatar
Do I smell a group buy?
Old 07-25-2018, 04:07 PM   #22
PCH
Was thinking the same thing.
Old 07-25-2018, 04:09 PM   #23
white855T
I recently bought another one and it was $330 shipped to me. You can place order on their website. Just use google translate. Price does fluctuate a little bit.
Old 07-25-2018, 04:11 PM   #24
white855T
They are already cheap enough. I think you can order 2-3 and pay one flat shipping cost but it would only be beneficial if you and a few of your local friends needed one as well, if not, the other buyers would have to pay additional shipping.
Old 07-25-2018, 04:54 PM   #25
ogamer777
Loading...
ogamer777's Avatar
$330 is not cheap to me. Granted, that's with shipping.
