Old 12-19-2018, 09:34 PM   #1
2turbotoys
Astro Zombie
2turbotoys's Avatar
Default Control arm failure, which way do they flex?
I got a precut set of plates to box my 242 control arms, the metal seems a bit thin for preventing the arm from bending in on itself, so I'm curious about how the arm fails. Does the "u channel" bend open or shut? The plates seem thick enough to prevent the top of the channel from spreading, but not collapsing.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 12-19-2018, 10:43 PM   #2
TestPoint
TestPoint's Avatar
Are you preparing one of our valued old Volvo's for a demolition derby?
Despite owning, maintaining and loving these cars for 40 years I have never heard this type of question come up.
Ford V8 Conversion Manual -
Old 12-19-2018, 11:02 PM   #3
Dirty Rick
Dirty Rick's Avatar
I think he is talking about boxing the rear control arms.
Old 12-19-2018, 11:05 PM   #4
TestPoint
TestPoint's Avatar
Why?
Old 12-19-2018, 11:12 PM   #5
2turbotoys
Astro Zombie
2turbotoys's Avatar
https://yoshifab.com/store/volvo-240...ox-plates.html
Front control arms. This really isn't a rare mod, it's been suggested to me several times for a high horsepower build that will see track time and hard street use. I've had a few Porsches that the previous owners had done this to.
Definitely not a demolition derby car, building a serious street car that can handle whatever it needs to. The control arms will be one of the most stock suspension components even after boxing. l aready bought JRZpro remote reservoir coil overs along with a ton of other stuff.
Old 12-19-2018, 11:18 PM   #6
2turbotoys
Astro Zombie
2turbotoys's Avatar
I believe Dirty Rick was referring to the trailing arms, which should be boxed if you use stock ones, I am not using stock ones.
https://www.bneshop.com/collections/...-trailing-arms
These are what I'm using.
Is this really an odd question? Why would this mod have been suggested a bunch of times? Why is it even available in our small world of RWD Volvos? Testpoint I believe your claim of 40+ years of not hearing it, but my baseline hp BEFORE turbocharging is 450 hp. With much larger rims and tires.
Old 12-20-2018, 12:45 AM   #7
Lando
Arthur Digby Sellers
Lando's Avatar
Think of it as a simple beam with fixed ends, and a downward load (the spring seat) in the middle. They will flex with a bow convex downward, meaning the channel will want to spread. It won't take much material to keep this from happening.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is offline   Reply With Quote
Old 12-20-2018, 08:08 AM   #8
2turbotoys
Astro Zombie
2turbotoys's Avatar
Thank you, exactly what I was looking for.
Old 12-20-2018, 10:08 AM   #9
F*ck 12
I used 3/16"plate for front and rear -insert butthead laughter
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 12-20-2018, 10:50 AM   #10
TestPoint
TestPoint's Avatar
What are ya'll doing to reinforce the unibody construction. How much HP and torque can spot welds take?
Old 12-20-2018, 11:00 AM   #11
F*ck 12
I have plans to stitch weld the body and reinforce the torque rod brackets, someday.
Old 12-20-2018, 11:54 AM   #12
towerymt
the real Towery
towerymt's Avatar
Ours failed like this. I don't know how/when it failed....before the start of a race Saturday morning I was noticing the tire clearance was lacking on the left front. I couldn't figure out why the tire was so close to the fender, looked at the other side, then back to the drivers side....something's not right here. Got underneath and found the control arm split open. I would guess that it was about to fail catastrophically, but loading/unloading from the trailer and turning the wheel sharply while rolling slowly may have yanked it just right to break BEFORE we started a 14.5 hr endurance race.
The arms were boxed, but some metal cut away from the reinforcing plate near the end because of the spacers we used between the control arm & ball joint. These arms were road raced for a long time and subjected to even more load with the wider front track hanging off the end of the control arm.
Here's another picture of a split control arm. On Pat D's 600k mile 240
http://forums.turbobricks.com/showth...49#post5744949
Old 12-20-2018, 12:15 PM   #13
towerymt
the real Towery
towerymt's Avatar
Think about how that control arm manages to survive with the bottom side open (not boxxed). It's fairly thick (compared to the reinforcing plates), and it doesn't fold up in normal road use or high-grip track use from what I've seen. Welding the plate across the open side makes it a box that would be much more resistant to crushing inward, like when slamming into a curb and folding the wheel back into the chassis. This is likely why the Volvo version didn't completely cover the bottom side of the control arm. It reinforced the weakest area, but still left an area to crush & twist.
However, I do think there is room for improvement. A hole saw and a dimple die could be used to make the reinforcing plate lighter and stronger.
Here's the volvo version of the reinforced arms.
p/n 1229923 & 1229925
$204.77 each at Tasca
Old 12-20-2018, 01:16 PM   #14
thismachine13
I'm noticing that Volvo ran their plate much closer to the two bolt holes for the lower ball joint.
Old 12-20-2018, 02:16 PM   #15
F*ck 12
I thought I saved the link to those racy extended tubular control arms from Sweden but I can't find it, anyone remember?
Old 12-20-2018, 02:26 PM   #16
culberro
culberro's Avatar
These? https://shop.klracing.se/sv/artiklar...-special-.html
Old 12-20-2018, 02:30 PM   #17
F*ck 12
Originally Posted by culberro View Post
So much sex for so little money
Old 12-20-2018, 03:36 PM   #18
culberro
culberro's Avatar
I’ve never bent a control arm on the track from braking or cornering forces, but instead from smacking curbing or dropping a wheel off.
The rally car has reinforced control arms, and they’ve never bent. Except for when a strut broke in half.
The drift car has KL Racing arms, and I bent them while dropping a wheel off track while drifting. Now they’re almost fully boxed.
The main benefit to the KL arms are the added caster you get.
Old 12-20-2018, 04:41 PM   #19
tjanson
tjanson's Avatar
Looks like the KL arms are 25mm longer and give you +5 deg caster? Am I interpreting the description right? Anyone know what +25mm will add to the camber?
Edit: I took a guess on the length of a ride height strut at 80cm (32"), and arctan(25/800) = 1.8 deg more negative camber. I don't feel like walking outside to measure strut length...
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 12-20-2018, 05:41 PM   #20
culberro
culberro's Avatar
With BNE top mounts and KL arms, I'm at 2.5deg camber and 6.5deg caster. I could increase camber a bit more, probably to 3deg.
https://www.bneshop.com/products/240...t-strut-mounts
Old 12-20-2018, 08:25 PM   #21
JohnLane
I had a pair of stock control arms fold up under braking on gravel with warm rally tires.
You track boys who've not had them fold up into pretzels are a bunch of pansies.
The right fix for this is available in Sweden and includes tubular control arms with spherical ends for pivots. I used Sellholm's kit. I have seen copies that look the part for pennies on $ellholm's dollar in Sweden. You pay for the good stuff. When the car is not wadded up once for it you win.
Old 12-20-2018, 08:56 PM   #22
quillc
yv1a.com
quillc's Avatar
Must see pictures of that (not doubting, just want to see).
Chris
www.yv1a.com
Old 12-20-2018, 10:10 PM   #23
JohnLane
This was the '90s. If at all was on film. Remember that?
Scott and I had been out practicing on the roads East of Issaquah before all the gates.
Tires were good and warm... Brakes had real pads and brake fluid... Stopping in a straight line and working at threshold braking... Firm application of the pedal... Steering got weird... Got out of the car to the wheelbase being enough shorter that front tires rubbed in a straight line over bumps and toe was off by a country mile. Control arms folded right up. We plated and stitch welded the next set. They lived until an oopsie; of which there were many.
Old 12-22-2018, 11:36 PM   #24
c1800
Sounds like fun!
Old 12-23-2018, 12:41 AM   #25
JohnLane
Originally Posted by c1800 View Post
Sounds like fun!
Rally car crack. First hit is free!
