Old 04-07-2021, 04:52 AM   #1
majkelos
Default 940 problems with lazy start
Hello, this is my first post here;) but I am driving my 940 for a while already.
I've tried quite a few tips to solve my problem but with no luck. I am struggling with a very lazy start, it has really no power until 2500-3000 rpms, then the turbo kick in and it begins pushing me into my seat.
I compared it to other 940s mine is the laziest... even comparing it to stock ones... I'm sad :(
My setup:
- B230FB
- 531 head
- Vx3 cam
- 16T turbo
- 465ccm green injectors from S60
- custom fuel pressure regulator with 3.8bar
- walbro 255 fuel pump
- original spark plugs
- AW71 gearbox with accu mod
- rear axle gear ratio 3.73
- 3” exhaust no cat
It is really slow at the beginning - comparing it to stock B230FT or even stock B200FT. It is so slow it is impossible to do burnout which is very likely to happen on B230FT.
What could be wrong? Any tips appreciated.
majkelos is offline   Reply With Quote
Old 04-07-2021, 05:12 AM   #2
hessam69
Could the cam belt be one tooth retarded?
Old 04-07-2021, 05:24 AM   #3
majkelos
This is interesting. I need to check it somehow.
Old 04-07-2021, 12:23 PM   #4
Fa182
Stage 1
Fa182's Avatar
Well there's not much happening below 2,500 on my B230FT either.
I'm also running a 16T at around 0,9bar.
Just an idea.
Are you running the stock Intercooler? That's quite a big limiting factor I've found after swapping to a 16T.
I was very disappointed because I've almost didn't notice anything.
It was only after upgrading to a KL Intercooler. See here: https://forums.turbobricks.com/showthread.php?t=343520
Also, how does your AFR look?
465cc injectors could be too big if you're not running a lot of boost pressure.
I'm still using stock sized injectors and they're plenty, AFR is perfectly fine with my setup.
EDIT: Are you using custom chips? I've bought a nice set from here and I'm very happy with them, gave a very nice upgrade.
Fa182 is online now   Reply With Quote
Old 04-07-2021, 04:48 PM   #5
majkelos
I am using custom chips - but I don’t trust’em. Maybe I should find the different ones. Do you have some trusted source for these chips here guys?
Regarding the intake - I’m running DO88s so the issue seems to be somwhere else.
Old 04-07-2021, 05:53 PM   #6
Fa182
Stage 1
Fa182's Avatar
I'm using these: https://forums.turbobricks.com/showthread.php?t=355788
I got them back when he started making them, but Swedbrick now sells them here in Europe, so get in touch with him if you want.
Old 04-08-2021, 03:18 AM   #7
Triebwerk
Could be a tired wastegate actuator. Had this situation a few months ago. Spool shifted 600rpm.
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
Old 04-09-2021, 05:40 AM   #8
majkelos
Hmm. Thanks. This might be an issue here as well. Is there any easy to find replacement for this or should I go for a brand new OE?
Old 04-09-2021, 05:42 AM   #9
majkelos
Thanks for sharing this. I will get in touch with him. Also I was thinking about buying an Ostrich 2.0 and some eprom burner and getting in touch with some shop who knows how to tune this engine. Unfortunately I am not aware of any garage like this in Poland..
Old 04-09-2021, 05:44 AM   #10
majkelos
Just an idea.
As for the AFR - on stock injectors and 1bar boost it was not very good, at the full throttle it was running lean mixture. I need to install some additional gauge and sensor in my exhaust, that's for sure.
Old 04-09-2021, 06:28 AM   #11
Fa182
Stage 1
Fa182's Avatar
Just to be safe, did you reset the ECU (by clamping off the battery for a while) and let it relearn after turning up the boost, so it can adjust the fuel mixture accordingly?
LH 2.4 is capable of doing that to quite a bit of extent, more than people might think in my opinion.
If that doesn't help, the chips might help too.
I've used a set of chips from an unknown source with an unknown fuel map before (came with the gold EZK and had to use them because I broke a pin off on my old TLAO ones) and the AFR was absolutely all over the place, terrible.
I'm using -768 cream/white V70 injectors at the moment (because the old stock -804's were leaking), but they have the same flow rate (about 340cc) and on full boost I'm well below 11 on the AFR gauge.
Old 04-14-2021, 04:49 PM   #12
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
If you're using a narrow band that's basically useless info
94 944 + lots of stuff http://forums.turbobricks.com/showthread.php?t=354303
Old 04-15-2021, 02:08 PM   #13
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Installing larger injectors without tuning the car will often cause fairly significant driveability issues, especially at part throttle.
I sell chips for LH 2.4!
Old 04-17-2021, 03:14 AM   #14
Wilford Brimley
So sounds like bigger injectors/no real afr/no tune is your problem...I mean it makes sense.
Old 04-17-2021, 06:26 PM   #15
redblockpowered
Yeah that's what I'd put it down to. Doesn't sound like there's anything wrong with it beyond that.
Old 04-17-2021, 08:18 PM   #16
mikep
The MP
mikep's Avatar
If it boosts when you power-brake it, how does the torque converter feel if you do a stall test? The stator clutch could be freewheeling.
Fun fact - bats having an extraordinary appreciation for sound and frequency are well known fans of Bose 901s and I have a feeling that's why it came into the house to begin with, it definitely stayed in the "sweet spot" throughout the visit...
Old 04-18-2021, 12:11 PM   #17
lummert
lummert's Avatar
Does black smoke roll under boost? If yes, try lower fuel pressure. I'm running Bosch Gen III white composite body injectors on LH2.2 with 2.5 Bar FPR. With 3 Bar FPR it runs too rich.
