Old 05-04-2021, 08:45 PM   #1
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Default 91 700/900 Power Mirror Operation Issues
Can't remember what to look for with this - mirrors operate properly L-R, but not up-down.
Wiring is all good - 91 740 is pre-wired, Mirrors came from a 97 V90, control with mirror switches, # 1362541 is appropriate for the year, according to the manuals.
Do the gears strip in the motor assembly?
EDIT - solution to using the late mirrors (with 2 drive motors & clip on glass) is to re-pin the switches as per the 93-diagram & use the 3545090 white base mirror switches.
Old 05-05-2021, 12:19 AM   #2
Coupid
Coupid's Avatar
Have you cleaned the contacts in the switch?
1988 745T http://forums.turbobricks.com/showthread.php?t=356096
1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 05-05-2021, 01:36 AM   #3
PCH
Couple of years ago I replaced the mirror on my '93 and I had to change the position of 2 pins in the connector, so compare the plugs first.
Old 05-05-2021, 02:19 AM   #4
MasterBlaster
MasterBlaster's Avatar
Did the mirrors just plug right in?
Any wires left over?
I've always found it odd how our mirrors work; a single motor with some kind of internal solenoid to switch the gears between left/right and up/down.
If the diagram is right, the Volvotips page for a 960 (called S/V90 starting in 1997) shows a mirror with two motors.
To me, it wouldn't seem to be compatible with a 1+solenoid switch.
volvopartswebstorel says it fits 740/940/960 up to 1993. Maybe 1994 was the big changeover in mirror motor count?
1990 740GL
517,000 km so far...
Old 05-05-2021, 09:09 AM   #5
lookforjoe
lookforjoe's Avatar
Thanks for the input. The mirror harness matches pin for pin in terms of both wire color & position in the harness - that was the first thing I checked.
I haven't tried cleaning the switches - I can try that. I'll see if I can locate a second switch assembly for ****s & giggles.
I have a stash of 5-6 mirrors from various year 700/900 (wiring matches harness on all variants) & they all operate with the same error - so it does seem the switches maybe the issue. Seems unlikely that all the mirror motor gears would be bad...
Old 05-05-2021, 01:15 PM   #6
Chris in Calgary
Interesting, I have the same issue after putting a 1994 mirror into a 91. Switch worked fine before the transplant. Please post if you figure it out!
91 945SE, 86 744T, 85 744T, 67 144, vintage BMW bikes
www.foothillsbrass.ab.ca
Chris in Calgary is offline   Reply With Quote
Old 05-05-2021, 06:44 PM   #7
lookforjoe
lookforjoe's Avatar
Swapping switches made no difference - I tried 4 others, all acted the same way. So, It has to be a difference in the wiring or a problem with the gear mechanisms getting stuck. I'll remove the glass & see what it looks like in there.
I'll update the thread with my findings
Old 05-05-2021, 06:51 PM   #8
PCH
Are wire colors in plug at the same positions old vs. new?
Old 05-05-2021, 06:59 PM   #9
lookforjoe
lookforjoe's Avatar
At the switches or at the harness plug for the mirrors? The door wiring is all stock & untouched. '91 is prewired for mirrors, so everything's just plugin switches & mirrors.
The wiring colors & pinout location is the same from the door harness as for the mirror harnesses for all the ones I have access to.
Old 05-06-2021, 12:21 AM   #10
dbarton
Dejected by Volvo
dbarton's Avatar
Mirrors and switches all changed between '91 and '92 from one motor to two motors. I have all of the info in my page, but most of it's pertaining to 240. But I have lots of 740 switch info and diagrams - photos of the changes, etc in my page if needed.
https://www.240turbo.com/240-powermirrors.html
Dave B
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80.
Old 05-06-2021, 07:16 AM   #11
lookforjoe
lookforjoe's Avatar
Dave B
Many thanks Dave.
I've been reviewing the 91 940 SE & 91 700 wiring manuals - that explains why I didn't catch the design change. I did get the schematic of yours for the late 240 setup from your website, however I can't find the section that contains just wiring diagrams for 92- 900. I have the Volvo wiring manual for the '93 960's I used to own, so I'll compare that. Looks like I just need to figure out which wires to re-arrange. I had already tried swapping one pair at the mirror harness to no avail, but I hadn't looked at a late diagram at the time.
Old 05-07-2021, 08:38 AM   #12
lookforjoe
lookforjoe's Avatar
So, I found a pair of later mirror harness sockets (where the switches plug in) and the sequence matches the later diagram (93) - so I de-pinned mine & rearranged to match. Still don't work as they should. I took the mirror apart & removed the motor assy, can't see anything wrong with the motor drives or terminal connectivity, etc. that would account for the lack of proper operation.
At this point, I think the switches for the later 2-motor housings must be a different internal switching configuration.
Going through the catalog, it's hard to determine as the number listed for 97-98 V90s (3545090) is the same (replacement) number listed for 91 740 (and 850s), which makes no sense.
Old 05-07-2021, 09:32 PM   #13
lookforjoe
lookforjoe's Avatar
OK - so I got two switch sets off an 850 - they have the 3545090 - can be identified by the white switch base vs. the black base of the earlier switch.
Not one of the 4 works in all 4 directions, however between the 4, each properly operates one axis - so 3545090 is the correct switch for the 2-motor mirror setup, along with repinning the switches as I have.
I've dismantled 2 of the switches to clean the contacts - before cleaning here
Old 05-07-2021, 09:52 PM   #14
lummert
lummert's Avatar
The switches are different.
Old 05-08-2021, 07:27 AM   #15
lookforjoe
lookforjoe's Avatar
Yes - That is apparent - if you saw my last post I confirmed the 3545090 white base switches are needed to accompany the 2 motor mirror assemblies.
Old 05-08-2021, 08:08 PM   #16
lookforjoe
lookforjoe's Avatar
Comparison of early & late mirror switches - very different internal connections. Mirrors work as intended now.
The later switches have no grease - early ones did. I added electrical grease to the ones I cleaned up
