Old 11-27-2021, 04:53 PM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default Hose nipple behind the downpipe. Should it have a hose?
There's a hose nipple threaded into the block behind the downpipes on an NA B230F. It's right at the rear of the block just in front of the bellhousing.
Should this have a hose on it? What is it for? It's not the coolant drain is it? Since it's literally just a hose nipple threaded into the block.
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 11-27-2021, 05:09 PM   #2
Old and boxy but good.
Yes, it is the coolant drain for the block. On the 940 turbos it does get a hose to it for the oil to coolant cooler setup.
Old 11-27-2021, 05:20 PM   #3
HiSPL
HiSPL's Avatar
Cool cool
Thanks
Old 11-27-2021, 06:10 PM   #4
Stiggy Pop
Stiggy Pop's Avatar
yeah that's the block drain. Sometimes they don't do anything when you break them free until you poke out the 200k miles worth of crud build up. Can also be a good spot for water cooled turbo plumbing.
'79 242
943 pickup
