haltechsupra
- Jun 22, 2004
- Texas
I have been tuning my car using a/f both on the ve target maps, and on the wideband o2 gauge -innovate mtx-L. I know that Lambda is actual air fuel ratio divided by stoichiometric burn of the fuel used, and is a lot easier to formulate percentages of fuel added or subtracted to an engine-as well as consistant with what percentage is lean or rich, where as a/f is not . However I find it difficult to make the transition from a/f to lambda. For instance , my mtx gauge has a lambda function I can set up. However my Microsquirt does not have an option where I can change target Air fuel ratios, to lambda, that I can find. I would also like to change from pump gas to e85, so that I can continue to road trip my car and run pump fuel and turn the boost down when I cannot find e 85 stations. Of course I can use the flex sensor, but it doesn't do everything does it(?)-like recalibrate the stoich scale on ecu, o2, or gauge? Right now I have just saved two different fuel and spark maps, and change them when I have to.
I know that lambda doesn't change depending on what type of fuel used, and a/f does. For example a/f of a rich running engine on 93 octane may be 10.1, with the stoich of pump gas being 14.7.or .68 lambda. But, on e 85 , 10.1 is lean, because e 85 burns at theoretical perfect burn( stoichiometric) at 9.8.1, so any thing higher than that would read lean, giving us a lambda of 1.03 which is way lean, even though you think your running 10.1-your not! So the whole scale on the o2 sensor /gauge/ ecu needs to be reset according the stoich level of the fuel I am now burning. I get a little crossed up on the different calibrations of the wideband sensors and gauges, and a little confused about a gauge that is calibrated for 14.7 stoich reading for gas , on what that reading should translate into for a safe e 85 mixture, hence the reason for me wanting to switch to a lambda scale to begin with. Consistency. Thoughts?
