Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Does anyone know where I might get some longer studs to press into my upper strut mounts? I want to raise up the front of my 240 a couple inches with a spacer.
Unfortunately the only fastenal I know of on cape is being completely re-merchandised so it is impossible to find anything until they get the store put back together.
Is there any reason I can't just use bolts in place of the studs?
I have yet to determine exactly how I'm going to make them, but I'll probably end up cutting a bunch of plates to the about shape of the ipd strut reinforce plates, stacking them, and welding them together.
I'm going to start with some of these: http://www.mcmaster.com/#7786t72/=123ig2c
and bore out the center with the oxycet torch, and drill out the bolt holes.
I probably won't weld them all together but rather stack them and torque the **** out of the bolts. This way I have some adjustment in the future, if I change tire size or add a heavier engine
Also if anyone has some of those IPD strut reinforce plates sitting around, it sure would help to have some measurements, like the overall diameter, and the diameter of the center hole.
I am guessing the overall diameter would be 6" but that was just from me looking at the top of the strut tower, and the bolt spacing.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
