and if I do pull off the M46 thing it could even be downright fun.
Without the European B280E cams, and I'd love to get my hands on a pair (hint hint!!!), I think 150 WHP or 180 at the crank would be a fair achievement.
You won't notice anything by ears. You just can see an error diode flashing or notice how power starts sucking because timing retardation.. search in this document, complete ignition diagnostic.. http://www.scribd.com/doc/18821915/TP31397-1-700-Ignition-IncompleteNo, I haven't noticed any knock at 2000, and all the piston tops looked like they've never seen a single detonation event. I would be interested in hearing about this "diagnostic output" you're talking about though!
I'm running on 95 (RON), and I want to try 98RON fuel...but since I'm also able to run on LPG (~RON 120) and engine is still knocking (true is, that ECU think, that engine is knocking).I was just having a discussion about fuel quality & ignition settings with a local guy, and how I've never noticed a difference in running between 87 and 90 octane (RON+MON/2), and wondering if the advance trim pin grounding tricks on EZ116K will work with the EZ115K.
