swedefiend
- Jul 30, 2004
I could rant for a minute, but I think I'm too tired for that...
I'll just stick to the task at hand.
I'm putting together a 91 b230 with mostly stock parts.
Everything was going good until I went to put the pistons on the rods.
I cannot get the clips from Venolia to seat with the pin installed. It looks like I need to take .001-.003" off of the length of the factory pin to get them seated.
I know the factory pin is tapered and that it would be important to keep them that way. Will it be okay to just lightly work each end with a flat file? Like slowly and carefully work each end just enough (trying ever so earnestly to keep the file perpendicular to the end of the pin) to get the length just right for the clips to seat?
Also, when fitting the pistons to the rods - do the arrows face forward on the factory pistons? I'm pretty sure they do but the Bentley just says to make sure the "notch" on the piston crown is aligned with the identification # stamped on the rod. I'm guessing that the notch must be on the earlier engines, because I've not seen one yet (and all of the engines I have scattered were 87+).
Anyway, the pin bosses are offset and I believe they need the fat side of the piston to face the starter side of the engine. I just want to make sure I get this right.
The rant would have to do with paying a machine shop to check things like this to make sure I don't discover them at midnight on Saturday night. Then me being naive enough to think that they would have checked the end clearances on the wrist pins.
Now I have a tweaked circlip and will have to work this out on my own after I order a few extra clips from Venolia on Monday.
The good news is that all of the ring gap clearances and rod/ crank clearances are exactly down the middle
I have been plastigauging my heart out because I am a little nervous now after all of the incidents with my "alternate" machine shop (read - not $90/ hr labor rate) although it appears it may have been wiser to shell out that dough.
Anyway, thanks in advance.
