This conversion has been a longtime in the making. Thanks for the information and support of the TB members and LS1Tech Hybrid conversions along the way that have provided guidance and motivation.
Most all updates will be in text and/or video blogs on YouTube. With Photobucket gone, I have been lazy on transitioning to a different picture hosting service. YouTube integrates well on my phone, which helps post information quickly and easily. Links will be provided as progress moves along. Note that I do not edit my videos or add any bling whatsoever, sorry if they are dry but at the same time they are short and zero rambletron to waste your time. I hate watching 15 minutes of blather for no real information at all.
The victim is a 1992 Volvo 960 wagon named Savage Wagon. Nothing yet is Savage about it at all... When backs up 400ish HP then the 960 will be pretty Savage
I know there are multiple ways to setup and install a LS powerplant in your Volvo swap. The goal is to retain all factory functionality with dash gauges and A/C. Basically a stock looking and functioning swap that you would be proud to daily. There are numerous swaps that have been completed that do not account for A/C, dash gauges, and any real efforts to make the car whole again as a real driver. Which is okay, but to get all the electronics right does require extra time and expense over a junkyard swap and burnouts. It really depends on what your goals are as to what you will gain out of this build thread.
All parts to make this conversion will be listed with sources and prices. Links provided to manufactures of custom parts and honest reviews of what works and what does not.
Other sites and places are dedicated to LS engine building and transmission selection. I will not bore you with drivetrain details unless someone asks. Basically it is a 5.3 truck LS engine with LS7 cam mated to a hydraulic Gen4 T5 transmission. The length and dimensions are very similar to that of a T56 and installation is basically the same. I know I have a mutant setup, it should work for me, but choose as you feel fit for your needs.
Basics:
- 2003 Silverado 5.3 engine modified with LS7 cam and supporting upgrades
- Gen4 T5 manual transmission - built up properly
- Hot Rod Works adapter plate
- SBC Truck bellhousing
- Speedway GM Hydraulic TO bearing
- 940T clutch and pedal set
- 940T Clutch Master Cylinder (M12x1.0 output)
- STS LS conversion mounts
960 engine harness will be modified to use:
- temperature sensor
- starter signal
- voltage regulation
- oil pressure gauge
- coolant temperature gauge
- power functions to control the LS ECU
ECU will be programmed by LT1SWAP.com. You can choose your functions depending on the way you pin out the loom. I plan on DBW throttle control and using the Fuel Composition Sensor for E85. Spreadsheet to follow on that detail. Note that once the car is up and running, a proper tune will need performed on the engine to optimize power and fueling.
The tunnel was pounded out per JTR 740 specifications. See their website for the PDF download... Bring a sledgehammer and move the metal quickly. Really, you will be there all day with a 3lb mini sledge.
Basics:
- starter signal
