D.E
tvåförti
- Sep 15, 2010
- Mora, Sweden
So I went and changed the oil in my 240 93 which was kind of like opening Pandora's box. I had noticed before that the oil drain plug had been changed for a different, allen-head one before but didn't think much of it until the time came to loosen it. It was sealed with silicone and it was clear that the threads were stripped. I took it out, did what I was going to do and tightened it up again as well as I could and re-applied silicone. But of course it leaks.
I don't really feel like dropping the oil pan so I thought maybe I can re-thread it. The plug is a 3/4" 16TPI and 3/4" means about 19mm. Biltema sells a kit that contains an M20x1.5 tap, drain plug and copper washer but since the recommended drill diameter for an M20 (coarse) thread is 17.5mm I don't think it's going to work.
I think that since they changed the plug the problem probably lies in the pan threads unfortunately and apart from JB Weld, I'm not sure how to fix it.
What does TB think?
What does TB think?
