iHateVolvoPeople
- Feb 1, 2014
- Midwest
Correct of course, but there are 8 valve actuations and only 4 rod bearings. A rod knock typically happens to 1, not 4. And I assure you I've beat this car up enough that if it were bottom end related, it wouldn't run anymore.The valvetrain operates at half engine speed, so any tick from the bottom end would happen twice as often as a valvetrain tick (if they're both singular).
Were/are you running valve hushers?
OHC redblocks run valve clearances that are about double what most OHC engines use. For example, DOHC Subaru engines use clearances of .007"-.010", and they are a direct acting bucket.
Could also be your fuel injectors. They sound very similar to excessive valve clearance.
Also, there is no reason to run a zinc additive or high-zinc oil on b21/23/230 engine. The shims are so large, the Volvo cams (and IPD) are so relaxed, and the valve springs are so weak. If you were using a flat tappet cam with little lobes, 1.5:1 ratio rocker arms, and valve spring force over 120lbs installed... then you'd want some zinc...
Nope never ran hushers. They came out with the first cam swap and it was silent then.
I really don't know how I can make this any clearer to the audience that it is valve train related. I appreciate your guys' input but it is absolutely valve train related. Yes, promise ring is fuvking retarded to turbobricks so surely he's wrong but seriously, it is the valve train.
