propav8r
F*ck Edgar
- Jan 17, 2010
- Franklin, NC
Dumb question but do you mean both the FI and body harnesses are damaged (RE: Lights), or something else? Just asking for clarification as questionable electronics are why I passed on a 242 recently despite having a really solid body. (Signal to make a right? Well I hope you like your cautions flashing instead... stuff like that.)
In for progress
I'm not sure what's going on with the factory underhood harness. The under dash stuff is just scary. Universal turn/flasher relays are cheap and easy to wire in. That's what I'll use there.
In reality, I'm sure I could make the existing wiring work. Josh was pretty methodical with the disassembly, but there's just no real reason to given the direction the car is taking. Simplicity is king.
