okoye
- Jul 27, 2009
- Connecticut
I think you may need bigger injectors man. Those look like the stock ones.
Googling 558 injectors indicates they are 440cc's, those aren't stock green tops. I still think his MAF is just dirty.
I've found the math isn't exact/linear. There are a lot of assumptions made with the variables.
I'm running 660's at over 20psi on E85, and I'm not leaning out. He'll be fine on 440's (42 lbs) at 20psi on pump gas.
The math can't be linear if your variable is a pressure ratio...
Oh wait, turbobricks. Sorry, I forgot.
Even a 440cc is a bit small for 20psi..
With a 3bar FPR and 80% duty cycle you're looking at almost 500cc for 300hp on a 4cyl.
440's are going to be running ~90% D/C for 300hp. Which I guess that's fine and all but if it were me I'd have some 550s in there.
Also yes, clean that nasty ass AMM
edit: but on LH 2.4, with chips and a bigger-than-stock AMM, isn't it recommended to increase injector size proportionally with AMM cross-section diameter to keep the maps playing nicely together?
Edit #2: Okay, math says 440 is just barely under 30% so as long as it isn't running lean injector size seems acceptable for 300hp.
