Fitted the level sender & pump to the 'new' sending unit, soldered pump & sender wires
made sure the pump was properly isolated - I had annoying pulse noise with the way I had it previously.
made sure alignment of sender tube to filler neck and vent tube was correct
Had to put a strap around base of the sender outer sleeve, it had expanded & the sender wasn't sliding evenly in the guide
installed the sender, wired the new harness
I had to make a right angle adaptor for the quick connect, the straight one wasn't going to work
Only problem I found out was that the hard line ruptured when I fitted the quick connect - sprayed gas all over the top of the tank, so I had to make a new line to the filter. Since I was going to replace it, I decided to remove the need for the adaptor, and the adaptor lines with flare fittings needed to go from the steel line to the sender & to the filter. Switching to 8mm ID nitrile line with quick-connects, and the filter (Mann WK-822) from an 850/x70 that utilizes quick-connect fittings. Old lines were 6mm ID.
10mm OD nitrile line, SUR&R quick connects
routed line with epdm sleeve added from sender to filter
just noticed the rear filler neck hose clamp is MIA..
Old filter setup had flare fitting inlet & right-angle banjo union outlet (filter not secured in this pic). No leaks & nice & quiet now.
