ZVOLV
<Master Tech>
- Nov 19, 2002
- California
... I suspect that is how I would do it. Would I die?
I urge you, and others, to go turn the key on, and then jumper coil negative to ground and see if they can get a spark. I couldn't get it to work consistently. I got it to work exactly ONE time. I consistently got arcing when I touched the jumper wire to the coil negative or battery negative, but that was it.
Post back with results.
EDIT-I got off my butt and did some tests.
Crank sensor signal wire tapping to ground. SPARK!!!
8 Second Video:
<iframe width="560" height="315" src="https://www.youtube.com/embed/i0kW1REDk3Y" frameborder="0" allowfullscreen></iframe>
Jumping coil negative to ground. ARRRRRRC!!!!
6 Second Video:
<iframe width="420" height="315" src="https://www.youtube.com/embed/uTonM3lE66g" frameborder="0" allowfullscreen></iframe>
