Kjets On a Plane
- Nov 12, 2002
- Californicated Oregone
What's so bad about the stock IC location? It has lots of surface area & can be stacked up in a sammich with the clutch fan to pull air thru it continuous to prevent engine bay heat soak?
Easy to service, not in the way of damage in the front down low, no moving parts? The factory did ok with that no?
I'm not convinced the 7/9 alt location is any better other than the temp sensor reference if the alt has an internal voltage regulator?
All 700 models come standard with power steering & they sold RHD turbo 7/9s, so it makes sense on those grounds recombining the junk drawer as Volvo did on the cheap...
More belt wrap/stronger brackets on the last of the 7/9 turbo models, but I'm not convinced any additional belt traction is available overall to drive the cooling fan & alt than the 240 has, really?
It's a little less 'afterthought' than driving the PS pump off the A/C compressor like the 240 does, eh?
& a little less busy than the 4-groove PRV crank pulley as a hold-over from the V-belt era & GIANT displacement Delco-air A/C compressor those came with some years...
But obviously in '76 when the SOHC 240 came out they mostly sold the cars to cooler climates & wanted to be able to offer them sans PS or A/C at all, so despite needing more alt than a 140 with its single impeller heater fan/single headlights only (B21F 260s had quad headlights starting in '76) & only 6 fuses without A/C except as an add-on and R12 only (don't need as much airflow), no turbos, they gave the 240 SOHC dual belts instead of the single fan belt for both alt & cooling fan/water pump that worked 'fine' on the B18s & B20s...
122s came with a 6-blade fan with optional dealer A/C is the only difference I remember, 140s larger alt and I forget what else was in the dealer install TSB
I never bothered, but did consider A/C for the 145 w/D-jet, power steering & OD trans added later? 2x foot vents, 2 pop out rear windows, 2 vent windows, live in the baker wilderness/where you don't need A/C (yet, climate change/heat dome...who knows now?).
I liked the MR2 electric hydraulic power steering, but it was worth more to a Toyota guy removed surgically with the entire front harness labeled so I had to give it up as a complete MKII MR2 kit as it was a rare option on those (most are manual steer except max factory kool-aid loaded 3S-GTE turbo models usually).?
I'm surprised no one has adapted the Saturn VUE/Chevy Equinox & Saturn ION electric assist quality Japanese/Koyo made column (I think they even used it in the couple odd hybrid Chev suburbans they sold I forget?) in conjunction with a ZF manual sturdy rack (which we got very few of (usually only as dealer replacement in a -'80 car back in the day) with the 2.5 turn guts from sweden to get all the power steering stuff outta the engine bay entirely?
IDK what you do for the brake booster? Hydroboost? For your Coyote crate or ford V10 modular motor installs stuffed into an uncut 240 engine bay?
Electric hermetically sealed A/C (or heat pump/battery pack temp heat exchanger if EV?) compressor sans hooptie shaft seals or hoses to leak out of the largest cabin toyota hybrid/EV to adapt?
Electric assist 14kw motor in the bellhousing/no hooptie belt-drive alt?
*Just* the engine/tidy engine bay/no plumbing or wiring nightmare?
IDK if I wish I had/was living the 'more $ than time' option?
...that might require working on someone else's terms & conditions or for a company or entity I don't feel ethically right about or paying bills/taxes, no? Kinda wanna be done with that for this life?
Or..U know...actually trying at life &/or giving/taking orders or exploiting others / consuming resources? Be nice to experience it to have a reference, even if only fleeting...
& having $ instead of skill/time off/relationships in life isn't really a life? 'There was once a lady that was so poor that all she had was money.'
Definitely a long ways away from the 4 houses & private plane of dead relatives before they pissed it all away to go rags-riches-back to rags (plus bill collectors from expensive habits ) again...
