- Jan 24, 2009
- KC, MO
sequential.... hmm....
now make one for a 4cyl.... also, injector drivers
http://miataturbo.wikidot.com/cop Lists 90919-02239, but not 02238. They may be very similar, but I think you would have to compare them to the 1ZZ coils. If they have +12v, ground, and a 5v trigger then they should work.Regarding the COP coils mentioned for the 1ZZ FE, I can get my hands on the coils from a 2ZZ with the part number 90919-02238 would these work just as well? Also Karl are there any boards left or are they all sold? and if so will there be another group buy?
Cheers
Paul
You can definitely hook up four coils. Just wire them up in pairs, but with one coil driver per coil.
I know I have declared my lack of knowledge in these things, but wouldn't it make more sense to begin with the stuff from the S40's with the direct ignition?
That's what drew me to the idea in the first place - the idea that most of the stuff could come off the shelf, ready made. I always saw the difficulty in getting all the sensors to work though - but I would have thought using the S40 coil pack set up was first choice?
Cheers,
T
S40 stuff doesn't really make sense for several reasons, the sensors being the least of your problems. The stock coil sticks won't fit a 16v head, so you would need to change them for something non-stock. The S40's spark and fuel computers are integrated, so you can't have one without the other. As far as I know, S40 computers are tuneable, so you're stuck with whatever mapping is on them.
OC1 Output coil bank 1 (to 1-4 side of your coils)
IB1 Ignition bank 1 (from buchka spark 1-4
VB Voltage Battery 12+ switched
TAC Tacho output straight to your 240 tach if miata unit, IF dsm unit, wire in a 12+ pullup wire with 1k ohm resistor tied into tach line)
IGR 12+ passthrough (unused)
GND Self explanitory
IB2 Ignition input 2 (to 2-3 side of your coils)
OC2 Output coil 2 (from buchka spark 2-3)
I don't know if anyone else has tried the launch control, but my friend who tested the original board in his daily driven 940 Turbo (who now runs a production board) has it hooked up. It works quite well.
Did he make up a bracket to fit the switch on the clutch pedal ??
I was considering teeing a pressure switch into the clutch fluid line, I presume this would work OK ??
it should be possible to reuse the cruisecontrol switch...?
@ karl. is there ans possibility to get a board within the next weeks?
i believe my 16v needs this
