Weight ratings are just limits put on you by the man, don't let the world limit you.No mention of the 750-1000 rated hitch ? (When new)
This weekend the car spent the whole time on the lift, main objective was the drivers floor. To do it out came the brake and fuel lines, along with the driveshaft and transmission. Good time to replace all the Ujoints, center support bearing and reseal the transmission in my eyes.
Driveshaft went about as expected, as in I got the wrong bearing and somone previously used a different shaft then should be in the car. After getting no response to my thread I grabbed the 66 style center support bearing and tossed it back together.
Next up came resealing the trans as it's been the biggest leak since the B20 went it and I didn't have gallons of blowby. Top cover seemed to be the biggest issue but I got the whole seal kit as a "while you are in there" thing.
The only issue is I'm ADHD'd out of my mind and can't leave well enough alone. Two of the gears on the main shaft had teeth wear and the countershaft matched, so instead of the floor it became an impromptu transmission rebuild.
Trans is reassembled and looking great. Not installed yet (gotta finish the floors) but it hasn't leak on the seat since filling it with fluid. Another one of those "while I'm in there" things came up when mounting the top cover. I've had the 140 style short shifter assembly forever and the schoolbus cover had some wear, so in went the other cover and out went the transmission tunnel.
I'm very pleased with how it sits, while I don't have the tunnel panel to install yet what's one more hole in the floor for a week or two?
