Nokutoto-Fuki-Arikatoka
If any link is broken, please let me know, until then please go to my PhotoBucket 780 Project Page Started the project last year actually just gathering parts. Started putting it all together the middle of June. Lots of setbacks (oh, so many setbacks) Rain mostly. I'm just hoping for somewhere in the area of 250-275HP. Nothing extreme, just drivable enjoyment. If anyone has suggestions, I'd like to hear them. Now, if I can just finish the projector lamps... Basic updates: Rear Sway Bar Install Painting New Grille S.A.M. Strut Tower Brace Side Marker Install AC condenser fan ALA Mr. Bill RSI stage 1 cam with RSI adjustable cam sprocket currently @ -2°. New front cam belt cover. (Mine disintegrated into dust, literally) "New" Turbo T3 .48 A/R I bought about 10 years ago, but only used for a summer. Ported 90+ Mikes Chips (Injection & ignition) 4 flow matched 52#/576cc model INJL55 injectors from Racetronix External CBV (Forge) 3" intake 3" 012 AMM Airaid AA720-431 air filter http://www.airaidsales.com/AirAid-Un...ters-PRD9.aspx Tucked up behind the bumper under the passenger side headlamp. ATP UIWG Ultimate Internal Waste Gate (3" outlet) NPR Intercooler Volvo 2 speed electric fan mounted in the stock mechanical fan shroud with 2-speed relay. Low speed side in the radiator using the "over heat" port. High speed control will be in the upper radiator hose. 3" turbo back exhaust custom made and installed by EurodesignMK with Magnaflow muffler and CAT. VDO OIL 80PSI pressure gauge and sender. VDO Oil temperature gauge. Sensor will be installed in the big assed banjo bolt for the oil filter relocation arm. AEM Wideband G-Valve Pics: ![]() ![]() ![]() ![]() ![]() ![]() Project link at Photobucket My Photobucket page
It's only an opinion. No harm is intended. ![]() 1990 780t Kind of Modded ![]() "Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?" My 780 headlamp mod thread My Mod Thread "Lister, you are a polyp on the anus of society." - A.J. Rimmer Last edited by Ursan; 05-01-2013 at 06:04 PM.. |
†500DollarSparkMap
![]() Join Date: Jan 2009
Matthew 10:28 And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell. ![]() |
Clever words here
Sweet.
-1990 780 Bertone-M46 N'stuff -2012 Triumph Tiger 800 w/ABS. |
#4 |
O hai!
nice, i have a gauge panel just like that in my s70
-Kyle- and his PROJECTS '98 S70 T5M-The overkill DD '84 242 TI-The RWD experience ![]()
#5 |
Emerged as Ugly Butterfly
Looking good!
So is that 2 oil filters?
'97 GMC K2500 Suburban 6.5TD - FailBus
'84 245GLT - FailWagon '92 245DL - The iFixit.com Lemons Car '95 850T5R - ButterCup Cheap 2/7/9 Camber Plates! Now w/Weld-In Steel! BrickSpeed - For Making your car fast. Not low. |
#6 |
2 filters, yes.
The issue I'm having is dialing in the right boost. I think the G-valve may have had it as a little loose makes almost no boost, a little tight & it blows hoses off. Better hoses than HG though, eh? |
#7 |
I'm intrigued! What's the advantage of this? Where'd you get the kit to run that?
#8 |
Hi, I'm Amanda Kutlewith
It adds about a quart of extra oil capacity without the need of a deeper sump or expensive pan. Also better filtration.
#9 | |
If I wanted to get sick about it, I could get the bigger 3001 filters which are even bigger. Or even still, we have Caterpillar filters here at work that are 14" long with the same base. But that's way WAY overkill. |
#10 |
The Sneaky F*ing Russian
your call is pretty neat!
![]() Current:|764Turbo *White-Rice* '86|Volvo 360 Cup '86|Volvo 144 '72|Volvo 242 '77|Volvo 740 '86|Volvo 360 Cup V2 '86|Volvo Amazon '65| |Brick Autosport|Brick Autosport Facebook!| |My seller feedback http://forums.turbobricks.com/showthread.php?t=147480| |
#11 |
call?
#12 |
I just love the 780s... That looks like a load of fun!
Dan Wildey 1991 940 Turbo Wagon 'Daily Driver' 1999 C70 Convertible, NGK Iradium's, IPd Sways, IPd SR5T Intake, EuroSport Exhaust 1996 855 (Wifey) 1988 744 Turbo... Soon to be done... Rebuilt B230ft (.030 over), T3/T4, 3" Exhaust, B-G Springs, Bilsien Shocks/Struts, IPd Sways, IPD Chasis Brace, Custom strut brace, Bar & plate IC, MBC, Autometer Boost and A/F ratio gauges,K&N Cone filter w/ heat shield, Blaupunkt Head unit w/ JBL 12", 850 Front Seats www.volvospeedshop.com |
#13 |
Last edited by Ursan; 12-12-2009 at 12:01 PM.. Reason: I had to move/name stuff. |
#14 |
Finally, as promised, another vid. But I'm not sure I like the sound quality
#15 |
(/// _ - )
Location: Receiving Transmission from David Bowie nipple antenna
That's sort of a girly car isn't it?
The Green The Red The Black The White The Bike Volvo parts I'm selling Custom 8mm sparkplug wires! |
#16 |
see that vapor? Pure estrogen.
#17 |
serial F***up
hahaha
EDIT: also, courb?
![]() www.brickspeed.net poopie scissors |
#19 |
The long lost pic of the oil temperature sender located in the big banjo bolt in the oil filter relocation deally. The E-codes. ![]() I spoiled my car. The catch can. ![]() Because greener is better. Last edited by Ursan; 04-01-2011 at 04:59 PM.. |
#20 |
serial F***up
so uh... 2009 project huh. looks good.
#21 | |
now dyno it...
1993 940T 2005 RSX Type S ![]() ![]() ![]() Quote:
#22 |
puuurddy!!
Never ending projects... -82' 242 Turbo - New Project -88' 240 - Daily Driver Project |
#23 |
#24 |
#25 |
| Thread Tools | |
| Display Modes | |
